By 55charliebird - 5 Years Ago
WHY ARE THERE SMALL OR MISSING HOLES IN THE NEW HEAD GASKETS WHERE THERE ARE LARGE PASSAGE WAYS FROM THE BLOCK TO THE HEADS? MY HEAD GASKETS WERE ON BACKWARDS (PRIOR REBUILD) AND IVE CORRECTED THAT ISSUE,,,,,,,,BUT YOU WOULD THINK THAT A 292 THAT HAS COOLING PROBLEMS WOULD TAKE ADVANTAGE OF EVERY WATER PASSAGE. (SEE ATTACHED PHOTOS)
By Robs36Ford - 5 Years Ago
Look at the heads. No holes in that top area. Bottom is not needed as there is others.
