By 55 GLASS TOP - 5 Years Ago
Hello does anyone know a part number for the bushing in the end brush plate for a 1956 ford starter . The end of the armature sits in a bronze bushing. Thanks
By paul2748 - 5 Years Ago
Maybe a local electrical repairer can supply you with the bushing
I will give it a try , if I can find one it seems like all the rebuilders have gone the way of the DoDo bird if it’s not in the computer at pep boys or advance auto parts it does not exist. I think I found a bushing listed in Macs catalog
By marvh - 5 Years Ago
This is info I got about Standard Motor Products Check out specs to be sure Drive end Standard Part Number X-4345 more details on - https://www.carid.com/standard/starter-bushing-mpn-x-4345.html?singleid=1856384217 Inner Diameter (in): 0.629" Length: 1.462" Material: Brass Drive end Outer Diameter (in): 0.815"
Commutator end Standard Part Number: X-5203 more details on - https://www.carid.com/standard/starter-bushing-mpn-x-5203.html?singleid=1856384216 Inner Diameter (in): 0.628" Length: 0.563" Material: Brass Outer Diameter (in): 0.753"
That’s good info thank you
By PF Arcand - 5 Years Ago
Marvh: yes that's useful info.. Don't recall you being on here in recent times..glad you are still with us. - Paul , in Surrey B.C.
