By Butch Lawson - 5 Years Ago
Found this on Facebook if anyone is interested.
.https://www.facebook.com/groups/fordyblock/?fref=nf
22 hrsAnyone interested in parts from this Y block? Was out of a 1954 F-900 big job As far as I can tell it’s a Lincoln Was a good runner ... Dropped a valve while in storage Has a small hairline crack in block below freeze plugs on one side. I’m keeping the fan hub assembly I also have an air compressor bracket for it as well PM me with what your interested in! Engine located in Aberdeen Washington Thanks See More
By yalincoln - 5 Years Ago
hi! the block casting # show's it's a 56 truck 332 HD. it should have a steel crank, same stroke as 368, and it has the late style holley 4bbl intake and ram horns exhaust that will fit a 368 Lincoln.
Thanks yalincoln. I bought the intake but there looks like a lot of other good "stuff" there.
sorry I see after closer look the block is a 63! it would be nice to know if it has thicker cyl. walls? it would still have a forged crank! not sure if it might have better rods?
