main/bearing oiling hole misalignment
http://forums.y-blocksforever.com/Topic149438.aspx
By Ace - 7 Years Ago
Should the main bearing oil holes be misaligned? For the 312.
http://forums.y-blocksforever.com/uploads/images/2e531ed1-c578-43d9-91f3-4a29.jpg
By Cliff - 7 Years Ago
Yes
This is correct?
http://forums.y-blocksforever.com/uploads/images/b92e5e9b-06da-4f1f-86f3-a2f0.jpg
http://forums.y-blocksforever.com/uploads/images/5a17bee5-7501-4747-b4d6-7a22.jpg
http://forums.y-blocksforever.com/uploads/images/599c8048-2c44-469f-bb5e-f946.jpg
http://forums.y-blocksforever.com/uploads/images/aaecb54a-1fcd-4edd-a6e8-2bd0.jpg
By 55 GLASS TOP - 7 Years Ago
Hello who is the manufacturer of those bearings thanks .
I have been grinding the holes in the block to align with the bearings' holes for years.  Scribe the outline of the bearing hole into the block and grind to the scribed lines.
By Florida_Phil - 7 Years Ago
Back in the eighties, Ford was selling out all their NOS 427 parts. I was able to buy a new side oiler block in the box.  I was told these last blocks may have minor defects, so I carefully inspected it. I have always used Clevite bearings.  My 427 block had the oil hole misalignment like the block in your photos. Since then, I have seen a number of FE blocks with the same issue.   I enlarge the hole with a grinder to correct this.  I believe it's a fairly common issue.
By Ted - 7 Years Ago
Main bearing oil hole misalignment on the Ford Y is normal for mains #1, 2, & 4.  A die grinder will easily correct that if it’s a concern.  It’s always best to do any grinding to the block before it goes to the machine shop for any work though.  If new cam bearings are already in the block when observing this, then leave it alone.
