By albjerryg - 7 Years Ago
I have a 1955 Victoria and the timing was off, after about 3 hours I was able to loosen the lock down bolt, I am having trouble trying to tighten the bolt. Is there a special wrench or technique to get to this bolt???? I don't know why they put the bolt in backside of the distributer. Thanks Jerry
By stuey - 7 Years Ago
https://www.sears.com/search=distributor%20wrench these may give you some ideas. I just got an old suitable socket and welded it onto some strap metal bent to shape. Doesn't look pretty but it works stuey
OK thanks that is good. Jerry
Got this one from my son. VM-104. The one from my dad was like a “U” but squared off corners. I also have one somewhere that splits in the middle and can be clocked.
By paul2748 - 7 Years Ago
I use an universal socket the correct size or just a regular socket on an extension if I can get the right angle
