By 55 GLASS TOP - 6 Years Ago
Hello I am going to pick up my block tomorrow from the machine shop, I want start to assemble the engine this weekend . I have purchase all the parts I need except the rear seal. I see there are a few options out there can I get some ideas what you guys think is the best to use. Thanks
Did you get a gasket set? It should be with that.
Best Gasket is a good one.
I did get the gasket set but have not opened the box , I guess I will see if it was included
By oldcarmark - 6 Years Ago
I used a Neoprene Seal with "The Right Stuff" in Place of the supplied Side Seals. So far its dry.
By miker - 6 Years Ago
If you haven’t read Ted Eaton’s article on the rear main seals, read it first. 292’s haven’t been as much of a problem, but the 312’s with the “orange” seal were a real problem. Guess how I know.
By Florida_Phil - 6 Years Ago
I had never had a Ford YBlock that did not leak from the real seal. After reading Ted's article, I followed his instructions and my 292 doesn't leak. It's not the seal, it's the rear seal retainer that's most of the problem. Great info.
