By Lawrence Petty - 6 Years Ago
Rebuilt engine and engine turned over fine with socket. Replaced cam with Isky 30144 and all went well. Now the engine will not turn over by hand. Took off tranny, clutch, flywheel, plugs and clothes pinned each valve push rod up with clothes pin. Still not turn. Could it be something to do with the tappets & cam - as everything went in fine when installing. Don't want to take engine our and tear it down, hopefully something simple I'm missing
By Cliff - 6 Years Ago
3 things to check, first did you time it right?,2nd did you check the end play of the camshaft after install? 3rd did the cam turn free before you installed the timing chain?
The timing marks were positioned as stated in the books. Never did check end play (what is the end play suppose to be) or turn it over before the timing chain was installed. Wasn't familiar with Y-blocks & since it was a fresh rebuild thought things would be OK. Anyway to determine tappet positions or anything else with the engine in the frame. Or just take it out and take it apart.
Which books? The book by James Eichman has the timing pictured incorrectly so if by that book, it's probably incorrect. I don't think that could cause a problem with flat top pistons, as far as turning the engine, with the Isky 301444 since the lift is .425".
Pull the distributor to make sure it's not locking the cam for some reason. If not, then I'm thinking that you reassembled the washers and spacers in front of the cam in the wrong order and it no longer has end play. Here is a recent thread about that. http://forums.y-blocksforever.com/Topic145717.aspx
You can remove the timing cover in the car, with the timing cover off loosen the bolt in the center of the cam gear, see if the engine will turn over, if so the end play is wrong, there are some books that show you a picture of the timing marks with the chain installed however many are wrong, use a Motors manual or a Ford shop manual.
By KULTULZ - 6 Years Ago
By oldcarmark - 6 Years Ago
Lawrence Petty (7/27/2019)
The timing marks were positioned as stated in the books. Never did check end play (what is the end play suppose to be) or turn it over before the timing chain was installed. Wasn't familiar with Y-blocks & since it was a fresh rebuild thought things would be OK. Anyway to determine tappet positions or anything else with the engine in the frame. Or just take it out and take it apart. Before You closed up the Timing Cover it would have been a good Idea to turn it over manually and make sure everything was turning without binding. Sounds like there is a problem with Cam Thrust Plate Assembly. There is a Min/Max Spec for Camshaft End play.
By Ted - 6 Years Ago
You don’t mention what timing chain set you are using. If using the Rollmaster set with the nine key crankshaft gear, counting the twelve pins between the marks can get tricky. Regardless of the timing set being used, the twelve pins between marks are counted on the oil filter side of the engine. If it is a cam timing issue, removing the rocker arms may allow the engine to turn over again but the Isky E4 cam is typically not a problem with valve to piston clearance. I'm with the others in that the cam to gear spacers may have been installed in the wrong order thus putting the camshaft in a bind with the cam thrust plate.
By stuey - 6 Years Ago
I had the same problem. New build in a 56 F100. New aftermarket dampener. I had the wrong front engine mount and the dampener was binding on the mount. Took 3 weeks to spot. stuey
My guess is that the spacer was not transferred from the old cam to the hew one. That's the one you put on the cam before the key is installed. That traps the thrust plate between the front of the cam journal and the timing sprocket, locks it up tight.
By Florida_Phil - 6 Years Ago
I had a similar problem when I rebuilt my 292 engine last summer. I installed an Isky 301333 cam in my engine with a Rollmaster timing set. The 301333 cam has a little more lift and duration than the 301444. After installing the cam I found I didn't have enough cam end play. It's .suppose to be .005", so it's not much. When I tightened everything up the engine would turn with a wrench, but it was obviously not right. The problem turned out to be the thrust washer. It seems like there were a couple of different thickness Y-Block thrust washers. I ended up taking the washers out of a good engine I had in my shop. I installed the cam without the timing chain and checked the cam end play with a dial indicator and it was perfect. It took me a week to figure all this out. The engine has been running for a year now and all is good. I have also seen Y-Blocks where the new cam bearings were too tight. I had that problem once and had to scrape the bearings.
Got it, there was a nick in the original counter weight that exposed a small nib of metal - once taken off got got spacing to 003 and all turns well. Would like 006, so does anyone know where to buy beveled spacers as I could not find any online ...thanks for responses
" ... where to buy beveled spacers as I could not find any online ...thanks for responses"
JOHN MUMMERT offers new on his website.
The only counterweight, on engines so equipped, is the fuel pump eccentric counterweight. Most have a spacer, instead of the counterweight. That has nothing to do with the cam thrust. They are items 6290. What you need is a 6265 that is .006 thicker than 6269.
Got it. Had a small nick on inside of counter weight that when tightened did not allow cam to turn. Once sanded off was able to get 3 on the back lash. Book said 1 -12 with 6 ideal. Does anyone know where to pick up the inner beveled spacers so that I can get to the ideal 6 backlash? Thanks all for the help, appreciated
