Pertronix Ignitor III wiring
http://forums.y-blocksforever.com/Topic146096.aspx
By Lawrence Petty - 7 Years Ago
Have a 292 Y-Block and have installed a Pertronix Ignitor III in my distributor and am using their coil.  To initially wire this to start engine and check system where do I put
the positive wire from the coil - to the Starter Solenoid "I" terminal or where?  As I do not have a keyed switch set up, only a remote starter.  Just engine in the frame right now
By Gene Purser - 7 Years Ago
If you have the correct coil with the ohms rating specified by Pertronix, you will just hook the coil to the battery positive post or any connection off of it. The "I" terminal on the solenoid is only hot when in the crank position. It is intended to by-pass a resistor if one is used.
