HARMONIC BALANCER BOLT
http://forums.y-blocksforever.com/Topic146048.aspx
AM GETTING READY TO INSTALL THE BALANCER.  ANY SUGGESTIONS ON "SHOULD I USE THE EXISTING CRANKSHAFT BOLT OR SHOULD I GET A NEW ONE"?   MY CONCERN IS "CAN THE OLD BOLT TAKE THE 90 LB. TORQUE.?  MY EXPERIENCE WITH MERCEDES BOLTS IS THAT THEY DON'T  RECOMMEND REUSING OLD BOLTS BECAUSE THEY ARE STRESSED AND STRETCHED  AND MAY GIVE WAY.  THANKS
By darrell - 7 Years Ago
they will stand 90 and more.reuse.
By MoonShadow - 7 Years Ago
When I did my blower setup I needed a longer bolt and got it from http://www.kljack.com/ We have a store locally so I just took the stock one over and they actually had the bolt I needed in stock. They can also order. I also buy stainless steel bolts from them and they are generally cheaper.
By paul2748 - 7 Years Ago
I've used the stock bolt over again in a couple of engines with no problems.
By Talkwrench - 7 Years Ago
90lbs no Problem.. Try doing up an early Ford rear axle nut [they're not big].. Over 200 lbs that'll make you pucker!
NO FEAR, THE OLD BOLT WORKED FINE.  90LBS AND HOLDING   THANKS
