Odd distributor mount... what is this about?
http://forums.y-blocksforever.com/Topic145885.aspx
Does anyone recognize this distributor and its mount to the block boss? I realize it is an HEI but the bottom of the distributor where the keeper mounts to the housing looks very different... almost seems as if there are two keepers.
https://www.youtube.com/watch?v=yb5VwFFqCfs
looks odd
By MoonShadow - 7 Years Ago
The heads and intake are from south America. I don't know if that affects the distributor too. The mounting boss does look different. I'm wondering if its a conversion for a non Y-block distributor. Looks like it sets an Inch or so off the block.
By KULTULZ - 7 Years Ago
I think what you are seeing is an MSD HEI dist with an alum cast/billet hldwn bracket.
What I am pondering is the CCV System he has.
AHA!
It's an adapter of some sort.  It's a GM style HEI.  The distributor bodies for aftermarket Ford GM style distributors are too short to fit without some sort of spacer because of their large diameter.  It looks like it would be even worse on the SA version because of the port layout.
I was involved in an attempt to make one available and it was determined that it wasn't worth it because a lot of the more expensive components would be Y-Block specific and therefore low production and high cost.
