By stuey - 7 Years Ago
good morning everybody looking for recommendations for replacement for M-5335-B. " it is used at any joint where there is movement or rubbing between two metal surfaces" originally asphalt /asbestos mix. there's a multitude of sealers out there some cheap some pricy some twin pack some single component. Thanks stuey
By paul2748 - 7 Years Ago
I use 3M Strip Caulk (Black) # 051135-08578. Even in a opened box, it still stays soft and pliable
By miker - 7 Years Ago
I use that as well, and have for 40 years. Used it when I rebuilt the doors/windows/etc a couple years ago, Its also between the frame and belly pan on my roadster. Cheap and it works. You can cut a short piece and roll it between your hands till it’s like thin spaghetti, then form it around parts as needed.
Thanks for the replies. Seems to be the stuff. Available on Amazon for £20 plus £27 shipping ! Found some 08568 in the UK , as far as I can tell it is slightly smaller in diam. compared to 08578. stuey
