By cokefirst - 6 Years Ago
I have a pinion seal leak on my skyliner. I replace the seal and it leaked as bad as the first one. I pulled the yoke and seal again and found a very slight groove caused by seal wear. I put a sleeve on the yoke, bought the Timken seal, uses a light grease on the seal and installed it and the yoke again. It still leaks. Any suggestions?
By ian57tbird - 6 Years Ago
I believe oil can leak under the Speedy sleeves. In the past I put a sealant on the shaft before I slide the sleeve on. Did you check that the seal felt like the fit was correct on the shaft/sleeve?
By 57RancheroJim - 6 Years Ago
I've had a few that didn't seal right away but after a few heat cycles they stopped leaking. Have you driven it much since installing it. Is this the large seal that was 57 only?
Are you sure it's the pinion seal leaking and not the O ring on the pinion housing that bolts to the front of the 3rd member case?
yes, I did drive it. there was no leak on the rack when i finished but after a drive it was wet again and fresh gear oil in a pattern above the seal. I did use the big seal that is 57. The seal seemed to make a good fit on the sleeve. There isn't much room between the sleeve and the yoke, but I will check that.
