| By tjaybo52 - 6 Years Ago |
		| what oil filter do I need for my 292 y-block.In a 55 fairlane club sedan I tried to look it up in old posts but couldnt find it. Thanks   Jim
		| By oldcarmark - 6 Years Ago |
		| Cartridge or Spin on? |
		| Sorry, sometimes on the forum I try to be brief then dont give enough info. It has the adapter for the spin on canister
		| By darrell - 6 Years Ago |
		| 302 or any of the old v8s work.fram number is ph8a |
		| By paul2748 - 6 Years Ago |
		| Don't use Fram.  Use the Ford one (FL1-A) or equivalent in WIX
		| By 62bigwindow - 6 Years Ago |
		| Wix 51515 |
		| By MoonShadow - 6 Years Ago |
		| Wix has been either the top or shared the top spot for most of my life. They filter down to smaller particulates than almost all others. I remember my dad insisted on Wix for his diesel trucks back in the day. |
		| ive seen someone put 100,000 on a 300 engine and never change the oil.knock when started but wore the truck out. |
		| By 2721955meteor - 6 Years Ago |
		| paul2748 (3/11/2019)NOTHING WRONG WITH A FRAM,have used them for40years no issues
		| Re oil filters - see this https://www.youtube.com/watch?v=iTNJLEV8CG8
		| i would guess the fram filter spent some time  out in the rain. i cut myn open on a regular basis,saw no issues,compared to wicks and ford found fram had bigger holes s  for oil  in than wicks or ford
		| By Joe D - 6 Years Ago |
		| Y blockers, I have been using a Fram PH8A. The engine is a 292 Y block that has been converted to a spin on filter. What is the Number of the Wix filter that I would use?
 Thanks for your help,
		| By Ted - 6 Years Ago |
		| The Wix number is 51515.
		| Thanks Ted, you the man!! |
