| By oldcarmark - 6 Years Ago |
		| I have done the swap to later Holley and Distributor on 56 with 12 Volts and originally a 4 bbl with Fordomatic. I have a Guy asking Me about converting a 55 with 2 bbl and Fordomatic. Will the later Distributor work with 6 Volts? What has to be changed as far as Linkage for the later 4bbl  with Fordomatic. If I recall the existing Linkage for 2 bbl is on the opposite Side of Carburetor? |
		| By pintoplumber - 6 Years Ago |
		| I have the later distributor on my 239. I’m still 6 volts. Only change was to the 13 tooth gear. |
		| By darrell - 6 Years Ago |
		| i have a friend who done that swap and he had to change all the linkage.even the kickdown rod was different. |
		| That's what I thought. The Link from Bellcrank to Carb is on the opposite Side for 2 BBL |
