| By blocky - 6 Years Ago |
		| hi i need to know what is the pushrod length and rocker arm length for a standard 272 that is out to 292 |
		| By charliemccraney - 6 Years Ago |
		| What do you mean?  Those don't necessarily change.
 Rocker arm length is not usually a spec people look for.  Do you mean rocker arm ratio?
		| yes the ratio and there are 2 different length pushrods  apparently.  i bought new rods and they are slightly longer??? |
		| If the significant change is that you bored a 272 to 292, then the ratio and pushrod length remain the same.
 Pushrods required depend on the heads, with '54,'55 and '60-'64 being long and '56 to '59 being short.  Factory rockers were 1.43 or 1.54:1.  High ratio are marked ECG.
		| By paul2748 - 6 Years Ago |
		| Check Mummert's site for push rod length
		| thank you to all who replied |
