What is it and what is it worth?
http://forums.y-blocksforever.com/Topic143928.aspx
By Melly - 7 Years Ago
Found a  C3TF-12127  K  Ford Dist.  3FB distributor in my garage.  Good condition, dropped it in my 292 and seems to work fine.  I believe it is a 63-65 Ford dist.  Could anyone tell me what it is worth?
could you send me a picture(with cap off)   ct1940@shaw.ca) i convert them to dura spark. thanks cliff tate
Here are photo' of Distributor
http://forums.y-blocksforever.com/uploads/images/a3774b79-f7da-4c87-9446-18e0.jpg
 http://forums.y-blocksforever.com/uploads/images/4b5ddd71-e665-4f9e-a751-89b1.jpg
http://forums.y-blocksforever.com/uploads/images/0a42fd2f-d347-4bae-9215-47b5.jpg
By paul2748 - 7 Years Ago
Off a 63  or 64 truck.  C3 indicates it was first used/made for a 63 and Y's were used only in trucks in 63 and 64.
Thanks for your info. This is then both a mechinal/vacuum distributor? Like a 1957 distributor, and has bushing rather then bearing, form what web told me. Does it have value for this and that is marked with Ford. From what I’ve read lots of problems with trying to buy over counter ones.
By KULTULZ - 7 Years Ago
Melly (2/12/2019)
Yes, it is a DUAL ADVANCE DIST. Like Paul said, C3 narrows it down to 1963 issue. You would need a TRUCK MASTER PARTS CATALOG to positively ID the original application. In addition, yours appears to have a FORD REMAN decal and additional ID STAMPINGS on the bowl.
FORD went to DA in 1957, a re-design in 1959 and another re-design in 1960. Yours is valuable in that cores are in shortage and re-builds assembled incorrectly. I guess the easiest way to value it is to review EvilBay to see what they are valued there.
Here it is as listed under 8cy. 292 engine. Also, the shop manual shows this strib could have a 13* or 18* centrifugal advance cam. This is the exact strib in my 64F100 and it had the 13* cam. This is a very nice distributor you have. Hope this helps, JEFF...................http://forums.y-blocksforever.com/uploads/images/32d1a260-ef30-405a-a2fe-25bb.jpg
