Y block marine parts
http://forums.y-blocksforever.com/Topic143009.aspx
By h2oproofer - 7 Years Ago
Trying to figure out the thermostat type on a 312 y block interceptor marine "dearborn"  as the thermistat housing was made by dearborn a standard 312 y block one does not fit it.   Anyone know what one dearborn was using?  spent hours at the parts store pulling them out and looking at them with no luck
Also have similar problem with the front crack seal thru the timing cover.   the stand y block has a larger diameter hole in it where the balancer comes thru.   the boat motor does not have a balancer only a pully.  the OD of the pully is smaller than the balancer.
needs a different front crank seal???
thanks
By Joe-JDC - 7 Years Ago
Is this still in a boat?  If not, then swap the front cover and intake manifold for a car or truck or whatever you need.  They are plentiful and fairly cheap.  If it is a boat, then put a want ad in classifieds might get results.  Joe-JDC
Yes still in wooden boat
By pegleg - 7 Years Ago
Take the seal to your local bearing dealer and ask him to match it up, or go to Interceptor and see if they have any ideas. Also visit the "Marine Engines " forum, they have a lot of information and parts connections.
By KULTULZ - 7 Years Ago
http://www.marineengine.com/boat-forum/showthread.php?438173-Interceptor-Marine-Parts-for-sale
