| By Kristian - 6 Years Ago |
		| Hi. I have a Ford F100 56' 272 Y-Block. I have bought the ECZ-9425-B intake and an Edelbrock 4 barrel Carb.
 But now my Load-O-Matic distributor doesn't work with the set up anymore, because of the only vacuum advance.
 Is this Dist from CRT an okay product.
 I am from Denmark, and i can't get my Dist Rebuild.
 If anyone can help i would be happy.
 Everything you need to upgrade to Electronic Ignition!
  WHAT ARE THE BENEFITS?- Better fuel mileage
 - Quicker cold starts
 - True Electronic ignition, no more points
 - More power + torque
 - Overall better reliability
 What's Included Brand New Small Cap HEI Distributor
 - CRT Performance 45K Old Style Can Ignition Coil w/ Bracket
 - 8mm, Custom Fit, HD Spark Plug Wires
 - All connecting pigtails
 - Extra advance bushing and spring as well as vacuum blockoff
 - installation instructionsThe compact design of the cap fixes the clearance issues of the larger cap HEI distributor.
 Unit comes ready to drop in and with a simple 3 wire hookup and your ready to go.Unit is identical in size to your point style distributor.
 Bring your old Ford back to life with True Electronic Ignition!
		| By charliemccraney - 6 Years Ago |
		| The CRT is a Chinese copy of an MSD.  It's a very common distributor rebranded and sold by many.  It can be found in a couple different colors. People have used it.  I haven't heard anything bad, yet.  My biggest concern would be replacement parts availability.  Are caps, rotors, ignition modules available separately or only as a complete distributor.  If the former, then it may be a good buy.  If the latter, I'd just buy genuine MSD.
		| By KULTULZ - 6 Years Ago |
		| Read This and Compare - http://4secondsflat.com/Ford%20Y-Block%20Distributors.htm
		| By 2721955meteor - 6 Years Ago |
		| 2 options 1 friend has a new ford list for block withe points,comes with a cap. 150 us. 2 modified y dis with ford duraspark adapted, new coil and mad box with inst200.00
 email ct1940@shaw.ca if you are interested. cliff tate
		| By PF Arcand - 6 Years Ago |
		| In the case of the CRT distributors from China, Is the product essentially the same as a MSD?  If so, why doesn't MSD file a Patent infringment claim?  It seems that many automotive products are being copied by Chinese companies, yet it appears that nothing comes of many of these cases.  Why?..
		| By oldcarmark - 6 Years Ago |
		| Maybe they have. Just haven't heard about it. Lets face it. The Chinese take a lot of Western Technology and copy it..As long as they don't sell it as the original which is called counterfeit they can get away with it. But I would be very concerned with replacement Parts availability. |
		| By Tedster - 6 Years Ago |
		| PF Arcand (1/6/2019)
 Manufacturing in China has certain requirements, one of them is turning over everything with regard to specs and proprietary info, every bit of it. The factory turning out MSD stuff may be cranking these out too, who knows. Intellectual copyright is a western concept, fuggedabout it.
		| Totally conjecture:
 My guess is that US Patent Law cannot apply to products manufactured in foreign countries.  Really big companies, like Apple may be able to afford patents or other means of securing their interests in other countries, to protect their products but smaller companies may not.
 If they are exact copies, possibly even manufactured by the same company, then replacement parts will not be an issue  Something else you get for the MSD price, though, is support  You're not going to get that with the Chinese product unless the company that sold you the distributor is willing to help out.  Don't count on any help from the actual Chinese manufacturer, if you can even identify them.
		| By 62bigwindow - 6 Years Ago |
		| I thought after a number of years a product was not covered under patent laws anymore. If that's true then that could be how the Chinese are getting away with it. |
		| By GREENBIRD56 - 6 Years Ago |
		| Once upon a time....... the US government would issue you a patent and defend your rights to it. Today, you provide them a clear idea of your idea - they verify it and record it - and you are on your own. Any defense of your patent rights is to your own account. Because of this - in this day and age "might makes right" - whenever someone investigates a patent infringement, they typically find the group with the most well funded legal team is always the winner.
 Another problem - when you get a patent, it has to be totally exposed to the public. Gives anyone with the wherewithal to build it a free blueprint. Virtually all of the modern electronic ignitions use the electronic scheme shown on a Motorola patent of years ago. Every automotive electronics outfit on the planet has clear idea of how it works - and they use it at will.
		| By Dave C - 6 Years Ago |
		| Took me a couple of weeks back and forth with the seller but I finally got the answer to the parts availability question Charley brought up. All of the parts are available through CRT Performance on ebay as well as a couple of other sellers. A replacement module (which they call a circuit board
 can be found here:
 https://www.ebay.com/itm/HI-OUTPUT-CIRCUIT-BOARD-MODULE-FOR-PRO-SERIES-SMALL-CAP-HEI-DISTRIBUTORS/232985253144?hash=item363f00d518:g:x3EAAOSwgYdb12qG:rk:11:pf:0
 Might not hurt to carry a spare if going on a long trip..
 Dave
		| By Aj64f100HiPo292 - 6 Years Ago |
		| The replacment 64 truck dizzy is a good one if you can find it. Easy to upgrade to durraspark II. But I know thats all over the fourm from when I did mine but Its an option that dousn't use GM style parts |
		| The ongoing Problem is finding a good original Distributor or even a good Core to rebuild. The Exchange Units that are (were) available from Cardone are not made correctly as far as Length of Shaft. |
		| By 56 Parklane - 6 Years Ago |
		| like you said its a copy of the MSD  their parts fit I  have one in my 292 and its been great  distributor and wires were 159.00 with free shipping on e bay and the machine work really looks good
		| its identical to MSD  , the biggest difference i saw was about 300 in price ,MSD moved their production to china ,that's when things get copied when the go to china ,dont think our laws apply in china regarding patent infringement |
		| By Tim Quinn - 6 Years Ago |
		| Put this in my '56 Crown Victoria over two years ago, could not be happier. Fires right up and hasn't missed a beat in two years. Modern day electronic ignition. NEXT: Fuel Injection ????? Tim in Florida
