By stuey - 7 Years Ago
Hi folks Vehicle is a 56 f100, front motor mount. Motor is 331 Y-block courtesy team Mummert. I have had it running on a test bed, sounded beautiful. Lifted it into the truck and bolted it to the bell housing. (c4 conversion) and found I had the wrong front motor mount. It did not reach the front cross member. Got the correct one and bolted every thing up. Feeling very happy I started on a twin exhaust and kind of left the motor for a while. Two or three weeks ago I decided to turn the motor over after it had stood for a month or more. It was stuck fast. Must be something in the bell housing. I slacked off the bell housing bolts and the torque converter nuts . Still stuck. Pistons frozen in the bores? For three weeks I've administered ATF/acetone and bumped it with the starter. First I would be lucky if it moved a degree or two later I nearly got one revolution. This morning I was watching the damper and I thought that's a bit shiny . The damper is rubbing the motor mount! Slacked the bolt and the motor whizzed over on the starter. So do I put a shim between crank and the damper or maybe spot face the timing cover to move the motor mount closer to the motor. Advice or feel free to chuckle please. stuey
Is it a stock damper?
Nope. its a billet steel version from Mummert. Which he no longer carries. I've been thinking, to shim the dampener out will throw my pulley alignment out. After spending a lot of time on getting it right and to spot face the timing cover may require shorter bolts so I will look at grinding clearance on the motor mount. stuey
By Ted - 7 Years Ago
The early pickup dampers (actually more of a belt pulley than a damper) were smaller in diameter and using the later model harmonic dampers tends to create some interference issues on the ’54-‘56 pickups. I have machined the early model front mounts so they would clear the larger diameter dampers but it’s usually easier to just use a later model front mount.
Thanks Ted I'm not certain what I have regards early or late motor mount, but I certainly have 2 different types. One which clears the damper does not reach the motor mount cross member and one that does reaches the cross member but does not clear the damper. I'll use the later and grind some clearance it should be well marked as to where the interference took place. The joys of Y-blocks stuey
