By MarkMontereyBay - 8 Years Ago
Email: yblock8@gmail.com P&G Valve Gapper 111-F in wooden box. $50 plus shipping from 95003SOLD 57 Tbird road draft tube $40 plus shipping from 95003 SOLD Summit 4160 4bbl carb new in box, never used it. $150 plus shipping from 95003 SOLD Yblock valley pan $40 plus shipping from 95003 SOLD 57 312 non-posted cylinder heads. Good condition. I took these off my Bird when I switched to Mummert heads. $100 each plus shipping but available for local pick up.
By NoShortcuts - 8 Years Ago
Mark. Sent you an email message to your gmail account this evening East coast time.
Regards, Charlie Brown
That's not a 4160. Do you know which CFM it is?
charliemccraney (11/14/2018)
That's not a 4160. Do you know which CFM it is? The label on the box lists it as a Summit 4160c and the CFM is 600. It is kind of a Frankenstein Summit version of a Ford and Holley that isn't available anymore. I remember when Ted tested it and was impressed with it. That's why I bought when switching from a the tripower to a 4bbl. Ended up using Mummert's 4bbl intake and a Holley 650.
Charlie. In looking at the Summit Racing web site, it appears that Summit has changed their numbering system pertaining to this carburetor. While I see two 600 CFM carbs currently listed, many of their Summitt offerings are for other CFM ratings.
I'm not sure when Mark purchased the Summit carb he is offering for sale, but I suspect that Summit has made some changes to what they are making and marketing since.
What I see is a Holley labeled on the box, https://www.holley.com/products/fuel_systems/carburetors/classic_holley/parts/0-80457S.
You're sure it's the 600cfm version?
The Summit carb is based on a Holley 4010.
Charlie is right about label on the box. Now looking at it after being on the shelf for several years, I probably put the Summit carb in the wrong box when storing it. I thought Summit quit selling it years ago and I can't find any information on their website. I contacted Ted Eaton who is familiar with the Summit carb asking for anything he might have on it.
After doing some digging found this carb listed on Summit.
https://www.summitracing.com/parts/sum-m08600vs
By PF Arcand - 8 Years Ago
As Charliemc indicates, that carb is similar to a prior 4110 Holley. In turn as I understand it, the "annular booster discharge" setup is a throw back to the Ford Autolite carbs that first came out in 1957-58. They were described by a former well known carb rebuilder as the closest thing to fuel injection, that wasn't. Apparently John Mummert's shop has had some success with Summit carbs.
