By MarkMontereyBay - 8 Years Ago
Edelbrock 573 with two Vintage Speed secondary carbs (no idle circuits, power valves or choke plates) and 2110 (94) center carb. Intake is in good shape, been sitting for a couple years on a shelf so carbs should be looked over. Includes air cleaners and what passes for a half-a$$ed attempt at fashioning progressive linkage on a 57 Tbird fordomatic with the spring loaded transmission kickdown linkage. Never got that to work but included anyway. $500.00 plus shipping (crated) from 95003.SOLD My email is: yblock8@gmail.com if you need more info. Edelbrock 553 intake (small port) in reasonable condition, some corrosion in the coolant passage and t-stat housing. Includes heater water valve. Don't know if it works. Offenhauser aluminum tripower intake good condition, again never used it just hung on the shop wall. $75.00 plus shipping from 95003
ECZ-B cast iron 4bbl intake, good condition (heat crossover port plugged). I ran this for years on my Tbird. SOLD $70 plus shipping from 95003
$100 plus shipping from 95003
By Daniel Jessup - 8 Years Ago
Mark, Sent you a PM this past weekend...
thanks, Dan hotrodreverend.com
Mark, I've sent an e-mail about the 573.
