By LordMrFord - 7 Years Ago
Let's see some pics...
...ummm...why my picture turned 90 degree?
By MplsMike - 7 Years Ago
With any luck this engine will be in the car this weekend!
By Rono - 7 Years Ago
 In my 56 Customline;
By paul2748 - 7 Years Ago
Lordmrford - right side up - did you use a phone camera??
By MoonShadow - 7 Years Ago
Ok, now explain the intake?
paul2748 (8/13/2018)
Yes. Maybe I should take vertical pics only.
MoonShadow (8/13/2018)
Its just simple intake manifold for motorcycle throttlebodies.
Too much butterfly tuning for street use so now those are locked open and I use plenum and single 70mm butterfly body in front of those.
Next thing is make new manifold without those throttle bodies. Just bungs for injectors.
This is the engine in my 54 before I took off the three 2's
By Lord Gaga - 7 Years Ago
I've been doing a lot of work. I think this will be the final configuration.
By LD-Ordie - 7 Years Ago
292 in my 55 Delivery wagon
charliemccraney (8/14/2018)
Ummm...Im looking picture of block with Y letters on its sides. :\
Cheers to all and the coolest, best running engines in the world...............yes, this 64 F 100 has the raised dot on the crank flange. Hope this pic is allowed, the beer is originally a Chicago (the area code) brew.
charliemccraney (8/14/2018) I've been doing a lot of work. I think this will be the final configuration. Cute
[/quote]
Oh, you mean this.
By Ted - 7 Years Ago
In Randy Gummelts’ ’56 Ford.
By miker - 7 Years Ago
The current y with the EFI throttle body in the bird
The F code in the 32
By dennis22 - 7 Years Ago
Just dropped this in my 59 F100. (Don’t mind the messy wiring, still have to sort that out)
By Rudder2fly - 7 Years Ago
I was stumped for a minute! Light Bulb!!! looking at head from bottom of the block.
Im spamming more random Y-Block related pics...
By Joe-JDC - 7 Years Ago
Found a new, easy way to check crankshaft clearance when using a stroker and stock oil pan with pick-up tube. Also easy to check clearances when needing light or a third hand.
This is definitely Y Block related. Joe-JDC
How about a 1150 cfm Holley carb on a Y? And the power levels just keep going up.
Ted, looks great. Is that a Mummert valley cover?
By Rowen - 7 Years Ago
Here's one of mine....
Here's Rowan's right side up
By mjs - 7 Years Ago
The LYB in my coupe.
By RB - 7 Years Ago
It is always nice to see the "Senior" Y block on display...
FORD DEARBORN (8/23/2018) Ted, looks great. Is that a Mummert valley cover? That’s a Yes for being a Mummert valley cover.
Thanks for the response and to everyone else for posting those beautiful engines with great innovation. Love it.......................
By Marc - 7 Years Ago
The 312 in my '57
And a few from a local show today...
