Thermostat for 55bird 292c.i.
http://forums.y-blocksforever.com/Topic137949.aspx
What brand and what temp. should I use.  In Florida.  Hot....very hot.
By paul2748 - 7 Years Ago
A lot of different opinions on this.  I use a 170 degree stat with a wide mouth.  NAPA  6  (THM6).  There are other makes with the wide mouth.  Another one I use is a Moto-Rad 320-170 that I found on ebay.  It has worked very well.
By oldcarmark - 7 Years Ago
]55charliebird (7/4/2018)
[/quote]
I am sure at least One Person will  suggest the "Robertshaw" Type Stat. I have tried 3 over the Years and not had any success getting them to work. Much better success using the "Widemouth" conventional Stats as suggested above. I used one of the TMH6 Stats and worked very well. Other Upgrades You might consider are smaller Water Pump Pulley and possibly an Aluminum  Rad..
By Tedster - 7 Years Ago
Looks to me that the colder thermostats like 160° F and 170° F were used with alcohol-based or methanol type antifreeze. Shop manual for '64 sez "All Engines" thermostat begins to open at 185° to 192° F, fully open 210° to 212° F
If you look at this Rotunda t-stat it shows 190° F despite the nomenclature on the box. It definitely looks to be higher flow compared to what's out there today.
It is important that any engine warms up quickly and to a sufficiently high temperature for engine cylinder wear reduction and boiling off sludge and condensation. The operator's manual allows that fuel economy will also be improved.
By Florida_Phil - 7 Years Ago
I live in Florida and my 55 Tbird ran hot in traffic.  A new thermostat will most likely not fix this issue.  You can put different fans on it, dump special coolant in the radiator and call a witch doctor and you will still have overheating in the Florida sun.  The way to fix this permanently is to upgrade to a Champion three row aluminum radiator and an electric fan.  This will fix your overheating forever.  I did this whole swap for around $350 and it was worth every dime.
http://forums.y-blocksforever.com/uploads/images/eacd04fa-231a-4e5a-bd3e-eacd.jpg
