By bergmanj - 8 Years Ago
Hi! I'm looking for recommendations for good flex-plate sources for my 1955 Y. Already looked for "search" & couldn't find - what am I doing wrong? Thanks, JB
By oldcarmark - 8 Years Ago
Macsantiqueauto sells new replacements. Stamped Steel One Piece without the separate riveted 'Ears" that came loose on the Originals.I bought One last Year.
By Lou - 8 Years Ago
Or use a 57 - up y-block flex plate.
O. K., I got the new one-piece flex-plate from "Larry's": No instructions. What side of the plate do the spacer shims (3) go on crank flange, or converter side? And (maybe "stupid", but I don't have the old one out yet) which way does the flex plate face - indents toward engine or converter? Or, is it "self-explanitory" once apart? I have the '55 "air-cooled" converter setup and have never changed one out - "Larry's" website says that the new one "also works on the air-cooled" converter.
Thanks, JLB
The Shims go on the side facing away from the Engine ( Convertor Side). They are to be used to space the mounting Bolts away from the Block so You don't end up with Bolts catching on the Block. I asked the same Question from Macs because there are No Instructions as You know. Should be some Instructions provided. It will only go on One Way. Using a 57 Flexplate is not really the Answer as they are hard to come by. This replacement Flexplate eliminates the problem with the originals "Ears" comming loose.
