Florida_Phil (4/6/2018)
The freeze plug that feel out was a factory style steel plug.  I agree the old plug probably wasn't seated correctly and the higher pressure caused it to blow out.  The old radiator cap was a stock 8 pound cap.  I do not know the pressure of the new cap as it came with the aluminum radiator.  My guess is 20 pounds or more.  I'll install a new plug and check the others.  Triple AAA is a good thing....
Most likely the new pressure cap is 13-14#. That is a lot on an old system which probably needs servicing to bring it up to speed. Unless replacing all plugs, maybe consider the stock pressure cap (less pressure) until a complete flush/plug replacement.
