need as much tech data specs and info on where to source out rebuild kit
Home
Keeping The Dream Alive!
Technical
http://forums.y-blocksforever.com/Topic136146.aspx
Print Topic
Close Window
By canada ken
7 Years Ago
Need as much information as I could find relating to rebuilding 1956 312 need any technical data torque specs and tips on where to source of rebuild kits and for some reason I can't find head bolts anywhere I look online motor won't be ready for rebuild for maybe a couple weeks I have time for any information you guys could give
By stuey
7 Years Ago
web sites:
http://www.ford-y-block.com/
http://www.eatonbalancing.com/
http://yblockguy.com/
books: FORD Y-BLOCK James Eickman FORD Y-BLOCK ENGINES Charles Morris
CD Daniel Jessup (Hotrod Reverend)
http://forums.y-blocksforever.com/Topic119830-1.aspx
and, of course, this forum.
stuey
UK
By Hoosier Hurricane
7 Years Ago
Check out John Mummert's website. Find it in the Links section of this site.
By NoShortcuts
7 Years Ago
Canada Ken. Welcome to the site. The previous sources offered are all GooD! I'm going to list several specific links on those sites so that you don't miss certain info in all that is offered there . . .
Click the links below to open the Internet pages I'm thinking of . . .
From Tim McMaster @ Y-Block Guy.com
http://yblockguy.com/techtips/yblocktorquetable.html
From John Mummert @ Ford Y-Block.com
http://www.ford-y-block.com/technical.htm
http://www.ford-y-block.com/assemblyerrors.htm
http://www.ford-y-block.com/troubleareas.htm
http://www.ford-y-block.com/price_sheet.htm
From Ted Eaton @ Eaton Balancing.com
http://www.eatonbalancing.com/2000/03/24/quick-index-for-eaton-balancing-articles/
http://www.eatonbalancing.com/2015/03/21/stock-ford-y-build-or-modified-here-are-two-different-approaches/
This Forum and the members who participate here have helped me enormously. There's information offered here that is not in Ford service manuals or service letters. The Forum Archive of past information shared is invaluable. Digging through the Archive can take time, but it's amazing what is there to be found.
Hope this helps you!
Regards,
Charlie Brown
By NoShortcuts
7 Years Ago
Canada Ken. The book Ford Y-Block Engines [How to Rebuild and Modify] by Charlie Morris is a good resource for your rebuild.
Barnes & Noble and Amazon are sources you might consider to obtain a copy. Click the link below to see a current listing for this book on eBay, too.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2499334.m570.l1313.TR0.TRC0.H1.XFord+Y-Block+Engines%2C+Charles+Morris.TRS0&_nkw=Ford+Y-Block+Engines%2C+Charles+Morris&_sacat=6000
Hope this helps!
