By Charles - 7 Years Ago
Anyone have or know where I can get a side oil dipstick tube ? I cannot use the front tube because the bracket hits against the Ram Horn Exhaust Manifold I have installed. I would like to run it through the center of the manifold. Thanks, Charles
You can get a stainless tube from Mummert. It will not go through the center of the manifold - if you're set on that, it will be easier for you to have it made.
http://www.ford-y-block.com/accessories.htm
Thanks for the reply, currently have that one which goes in the front port but becuase of the bracket will not fiit in the side port due to my manifold. If I could get a tube without the tack welded bracket that would be great. I will call mummert and see if the can make one withoit the bracket.
Look farther down the page. There is also one for rear sump. I can confirm that it fits the rear sump location because I have one.
Thanks for the help, I was able to find one in my home town. Thanks again.
