Edmunds dual carb manifold
http://forums.y-blocksforever.com/Topic135229.aspx
By Kev - 7 Years Ago
Hey guys,
I found an edmunds dual carb intake. The sellers says it’s for a 312. I have a 292, I believe those two motors are fairly similar. This manifold should fit ??
By Rowen - 7 Years Ago
Yes
Thank you
By PF Arcand - 7 Years Ago
Is it a dual four barrel intake?  That would make 4 intakes, including 3 Tri- Power's, that they manufactured for Ford/Merc Y-Blocks.
By Ted - 7 Years Ago
http://forums.y-blocksforever.com/uploads/images/0f46e285-89f8-49bb-b630-4f8d.jpg
Edmunds 2X4 intake manifold.  Here are the links where the various dual quad intakes for the Y including the Fenton and Edmunds are dyno tested on both the iron and aluminum heads.
http://www.eatonbalancing.com/2014/01/15/y-block-ford-dual-quad-testing-on-iron-heads-part-i/
http://www.eatonbalancing.com/2014/01/17/y-block-ford-dual-quad-testing-on-aluminum-heads-part-ii/
