By cos - 7 Years Ago
Hello I have std bore 312 block that has been freeze cracked. I don't know why I saved it (30 years) but I did. The crack is about 2 1/2" long on right front edge (flat part) just before where right side starts. It is a very fine crack, unless you hot tanked it or really looked hard, probably would not see it. Any way, does any one here had any info or advice on fixing it or junking it? I have researched a little using stitch and lock. They make it look easy BUT I have been told that is easy to break taps off, that where trouble starts. It will cost over a hundred dollars for parts if nothing goes wrong. Iam thinking it is not worth risk and sent it to China. Bill Oregon
By Dave C - 7 Years Ago
A good welding shop should be able to weld cast. Reason I mention it is because many years ago the shop I worked in used to take the 250 scruby 6 cyl integrated head to Indy Cylinder Heads in Indianapolis. They were very prone to cracking in the combustion chamber, and at the time expensive and hard to find. We would get them back looking like new. But, after saying that, welding cast with nickel, stainless rods is pretty much a lost art. In the past... I made a repairs on a 4x4 front differential ring gear carrier by welding up an oblong hole where the spider gear pinion shaft went through by brazing it. I have also brazed up external cracks like you have in blocks and brazed exhaust manifolds back together that were in 2 pieces. In todays world that wouldn't fly and people would think you were nuts to even mention it.
Today, if I had a repair like you have I would use the lock and stitch method. I know you said you were afraid of breaking the tap, but as long as you take your time, use the correct drill size, watch your pressure while tapping, and your tap stays nice and sharp you probably have nothing to worry about.
Anyway. Just a thought if the block is worth saving otherwise.
My .02 worth.
Dave
By Dobie - 7 Years Ago
If there is a shop in your area that repairs industrial castings you might let them have a look at it. They will magnaflux it to determine the extent of the crack and give you their opinion of whether it's fixable. I had a shop fix a couple of flatheads 20 years ago and they're still going strong. It sounds like it's in an unstressed area so you might be good to go.
By PF Arcand - 7 Years Ago
As Dave C says, it is feasible, but before you precede, best to check closely for Main bearing journal area cracks. Unfortunately, cracks are fairly common, in 312 blocks, especially if the block is a 1956 casting, due to a spec error in main bearing torque, that was published in manuals!.. And over zealous rebuild torque settings also contributed to cracked blocks or stripped main bearing threads.. Good luck!
the harnand chain lock was used to repair early d8 dozers 2u trans and steering clutch aria a,large casting.the co that did these repairs did hundreds hear in bc,we also repaired engine blocks. that had asuply of the cross chains which went into inter connecting holes,these wherpeaned into place every2in of crack; then pip plugs in-between so no leakage. worked great if we got there before some welder tried 1st. cast is easy to drill if no one is near trying to weld. email harman chain lock repairs.you should get a idea. if the block is good other than the crack should be repairable. crack in rear main aria is not repairable
2721955meteor (2/8/2018)
just went to google and found a site which shows the process under cast repairs block and chain system or harmony chain lock cast iron repairs
Thanks for replies. I will ckeck out chain-lock type repair. I wire brushed cam bearing bores to main bearing saddles noting showed but I have not hot tanked it yet. Bill Oregon
By Ted - 7 Years Ago
I’ve been successful at stick welding external freeze cracks in cylinder blocks using nickel rod. The blocks do need to be cleaned first and a little preheat around the cracked area does tend to help the rod melt to the cast a bit easier.
Ted (2/9/2018)
I’ve been successful at stick welding external freeze cracks in cylinder blocks using nickel rod. The blocks do need to be cleaned first and a little preheat around the cracked area does tend to help the rod melt to the cast a bit easier. nickel works some times,there are lots of cast rods out there some work some do not,but all make the welded aria hard and the chain lock won't ever work as you need to drill the maney holes. the experience welder tells me the main isue with cast iron is every casting has different content and nickel will work ,the next bock or head won't. peaning the weld helps as does slow cooling.due to welding it pulls the welded material, cast iron is brittle,peanigdecreases the aria so crack does not reaper
By 56_Fairlane - 7 Years Ago
Epoxy may be an alternative to welding. Several years ago I was interested in a V16 Cadillac that had a cracked block. I found a place in Portland that would have probably been able to repair it. The deal ended up falling through so I never pursued it further. Unfortunately I also lost the company info that would have done the work. I'm sure they'd turn up in a internet search if they're still around.
By jecklhyde - 7 Years Ago
I've welded lots of cast iron over the years, from engine blocks to transmission cases, even a lathe saddle that was broken in half. Eutectic makes a good rod specific for cast, the last I bought was $200. a pound. Clean the area good, grind the surface a little to get to clean cast; I doubt I'd vee the break seam since you might go through.....likely cracked in the weakest area on the block. Pre-heat; I usually spit on the area, when the spit bounces off instantly it's ready; the welding process will then keep the area sufficiently heated. Use small rod, say 1/16", weld in 1/4" to 1/2" lengths, peen immediately, wire brush and make the next weld. You'll know if the casting is good or poor by the forming of pin-holes and popping in your welds. The good Eutectic will bond it up, though, I expect. Then "glass" the block....may even have a better block sealing chemical process nowadays. Don't buy that cheap-asp ni-rod....results are like the difference between night and day. And, the one worry I'd have is blowing through and making a big un-fillable hole. Good luck
I've never had much to do with cast arc welding, but if I recall my limited training in that area, other prep things to do are these. Try to ensure the area does not have water in it & is clean. (oil or water will likely cause porosity) Then examine the crack carefully, use a magnifying glass if needed, & then drill a small hole at both ends of the crack. This is supposed to help avoid further migrating of the crack. Also, avoid any sudden chilling of the welded area.. Goodluck
By Shaggy - 7 Years Ago
I'd be tempted to braze it
By MoonShadow - 7 Years Ago
I had a cracked water passage on an engine block. I found a block repair epoxy that is used for boat motor repairs. It worked great. I used a grinder to hog out the area around the crack so I could get a good bite on the metal. Worked that way for years. Sorry I can't remember the name of the epoxy but try a local boat shop.
The problem I've found with trying to braze up something as large as an engine block is keeping the heat, tries to run away.......if you get the block hot enough to correctly braze you'll need to have the block checked and re-machined after the brazing job. Make short welds with the best rod that money can buy. Peen immediately after each weld to keep the weld from shrinking away from the block and cracking where the weld meets the block cast. After you get the five or six beads (length of the crack) ran grind the weld , even smooth, to check for pin holing.....as mentioned the crack will hold trash and the welding will draw it up into the bead. If you have pin-holing grind it smooth and run more beads down the center doing the same peening and cleaning between each bead. May even need to run other beads down each side of the center bead. You can readily tell when you have good clean bonding. Peening drives the weld into the grain as well as keeping shrink to a minimum, as in ....stress relieving. Check out Eutectic and other major brands for specific rod for the job. The one I like....you can even weld bearing races together....break them with a hammer and they won't break at the welds. I'm retired and my memory ain't that good anymore......seven, eight, maybe even ten years since I've done any serious cast iron welding. Do your homework. At two and one half inches long the crack should be an easy and quick fix. I'd still use block sealer as an added precaution. . And, one you start, finish the job, while you have heat in the area. d
