By Rowen - 7 Years Ago
Can someone please post a pic of what they have done for throttle linkage with a mummert intake and a edelbrock carb. I got a stock 4v set up except it is for an automatic. Do I need one for a manual? Any help appreciated
By paul2748 - 7 Years Ago
Do you have an automatic or manual trans? When I did the 312 with a 4BBl (Edelbrock) and top loader 4 speed in my 54 Ford, the only thing I had to do is make the flat rod off the linkage a little longer and then run a rod from that to the carb. If you have an automatic (Fordo?) you have to use the regular linkage. I assume the Mummert manifold had the correct mounting points for it.
By Ted - 7 Years Ago
As Paul mentions, the throttle linkage for a standard transmission equipped car is reasonably straight forward in that the firewall bellcrank can attach directly to the carburetor. Here’s a picture of such a linkage setup on a ’56 Ford.
By Lord Gaga - 7 Years Ago
Didn't O.D. equipped cars like the one pictured have a spring loaded linkage rod to compensate for kick down switch travel?
