I have a chance to get a rear 56 bumper with the exhaust openings, The guy said it was for a wagon and was wrapped that way from the plater a while ago, but I've never seen one with the openings. Are the wagon and car bumpers the same? Thanks
quickly, my parts manual only shows one # ...17906 and says typical
By 56_Fairlane - 7 Years Ago
There's two part numbers, one with exhaust openings and the other without. Same bumper for all models except "79" whiscruber that one is.
By Rowen - 7 Years Ago
I believe the bumper exhaust ports where an option. It will fit 55-56 et al.
Only the '56 292 and 312 equipped cars usually got the bumpers with the ports.
By Talkwrench - 7 Years Ago
If the chrome is good grab it anyway! Getting good chroming done is very hard now, I think you guys would send it down to Mexico. Over here its crap work and the starting price is $1200 each to be chromed
As a note I never saw a Fairlane without the bumper and I never saw a 6 cylinder one either. The only different thing I knew about the wagons were they had different bumper guards and I've seen those.
The price was very good and the chrome had no flaws I could find, the back side still had the silver paint from the plater and the welded washers to do the dipping. I went a head and bought it. I'll repaint the silver to a dark gray from Eastwood like I normally do. Thanks all who answered.
By PF Arcand - 7 Years Ago
Use the bumper if you want to, however if I recall, all Station Wagons had splayed exhaust outlets behind the wheels for safety from fumes..
By tarheel - 7 Years Ago
Drylakesracer: There were 2 bumpers used in '56, one with the exhaust and one without. The ones without were mainly used on wagons and sedan deliveries. My understanding is the the wagons would pull the exhaust from the outlets into the car, if the back window was open. I have no idea about the sedan deliveries but guessing it was a cost issue. I have seen several '56 Ford Victorias with the wagon bumper guards. To me they look a little funny, but different people see things differently. Larry
By carl - 7 Years Ago
If the 56 car had dual exhaust from factory it had ports in the bumper other than wagons and sedan delivery's which didn't have the ports Carl
That's what I always thought too. I did see a Parklane with late model running gear at an auction and he said he added the bumper. I knew a family in the 60's that put duals on a wagon out the back and couldn't even crack the rear window. had to change the tips to aim out the side, The 56 Bird had weird tips and I'm guess as a convert there must have been a problem from the 55 but the 57 went out the back again..... thanks all.
By oldcarmark - 7 Years Ago
The Rear Bumper with Exhaust Ports was only on the Fairlane Series. Everything else had the conventional Tail Pipe Exhaust. Bumpers will interchange in the same Year Vehicles but I am pretty sure there is a difference in the Bolt Pattern of the Bumper between 55 and 56.I have a rear bumper Filler that the Rubber goes on from a 55 and could not use it on my 56 because the Bolt Pattern was different.
By MoonShadow - 7 Years Ago
I think the main brackets are similar but there is an additional brace that goes under the exhaust out to the end of the bumper. I will say that on a car with this type of through bumper exhaust you need a good trunk seal.
The brackets are different as can be seen in the diagram.
Paul these are not splayed. they are straight out the back like normal.... The guy advertised the bumper as a station wagon because it said so on the wrapping,
Finally went over and picked it up and it's a match to one I have but my needed replaying and had peeling chrome on the right corner and a dent there too. It may have been plated a while ago but weather and no sun ever touched it. It was WAY under the price of replaying one...bout half.
There's a guy in Whittier about 20 miles from me who had a perfect show chrome front and I have some peeling on mine. Looking to see what he will do in trade for a rear and front for his front. He is very proud of his work but only does show work no single plated all 3 correct nickel, copper, chrome.
