By junkyardjeff - 8 Years Ago
I am going to look at a 59 this weekend and the 292 that is in it will be used for the build of the motor for my 55 sunliner so I was wondering what heads should it have.
By miker - 8 Years Ago
This chart from Mummert’s site will show what was stock. Or what’s replaced them.
http://www.ford-y-block.com/cylinderheadchart.htm
By NoShortcuts - 8 Years Ago
Jeff. Miker's reference to John Mummert's web site should be helpful, IF the heads were not swapped over time.
Isn't it interesting that such different heads were used on the different makes of FoMoCo vehicles that year in spite of them all having y-blocks?!
Let me add to what JM's reference list for '59 engines shows . . .
292 Ford passenger cars with 292 engine . . . . . 5752-113 heads 292 Ford LD, MD, HD trucks with 292 engine . . . 5750-471 heads 312 Mercury with 312 engine . . . . . . . . . . . . . . 5750-471 heads 292 Edsel with 292 engine . . . . . . . . . . . . . . . . 5752-113 heads
Best Wishes on your hunt. Hope this helps!
By PF Arcand - 8 Years Ago
As Charlie points out, authorised rebuilders & others often swapped out used heads for what they happened to have on the shelf. It was often common practice. My 59- 312 engine came to me with 2 -1956 heads on it & the casting numbers were not a match...
By Ted - 8 Years Ago
I typically find the ‘113’ heads on unmolested 1958-1959 car engines. Some of the early '58 engines will still have the 'G' heads on them. Unfortunately, there’s not many of those engines sitting ‘round anymore that hasn’t had some of the parts changed out. If the engine has composition head gaskets, then it’s suspect before tearing it down that the engine may not have many of the original parts remaining.
