57 ford transmistion
http://forums.y-blocksforever.com/Topic133094.aspx
By spud 57 - 9 Years Ago
I'm in need of some help my car was last run in 78 it has a 312 with a 69 small case fmx with a ford-o-matic front pump.It slips into 3rd so I will be removing it over the winter. Before I redo it I was wondering if there were any better set ups back then you can't do much for converters with the ford-o- matic.I do not what anything that was not available in 78 trying to stay period correct. Thanks
Contact California Performance Transmission tech support 714-901-3777 and ask for Art. He has been racing Ford transmissions since the 50-60's and can definatly guide you and supply a converter to meet your needs. They dyno run every transmission and make their own converters.
By PF Arcand - 9 Years Ago
Not sure of my ground here, but from your info, it sounds like someone already mated FMX & Fordomatic parts to make a particular transmission coversion. This had been done before for higher performance setups by people such as John Feistritzer, better known years ago as the owner driver of the " Hoozier Hurricane" a very successful 1957 Ford drag car.. With the right combo of parts it makes the  trans into a rugged 3 spd auto.
By stuey - 9 Years Ago
I think there was an article   "Y NOT A Y-BLOCK" that covered that.
stuey
By oldcarmark - 9 Years Ago
stuey (10/18/2017)
stuey
There's actually an Article about this if You check under "Articles" at the Top of Page. Good reading.
- I believe John Mummert Manchine sells a Ford C-4 adaptor setup for Y-Blocks (link from this site) Also there are one or two outfits that do EOD conversions, although it's involved & somewhat costly. One is Gary Croan, Costa Mesa CA,  e mail garycroan@gmail.com or 949-722-1122.
P.S.- Stuey's, previous reference is to info in the Y- Notta Y-Block series of articles in Street Rodder, 1999.. Useful, but unfortunately they are long out of print,  so U would have to find them used
