By Florida_Phil - 8 Years Ago
My 1955 Thunderbird has a Borg Warner T86 3 speed light duty overdrive transmission. When I lock out the overdrive by pulling out the handle, the car runs fine. When I push in the handle, the car seems to shift into OD OK, but the whole drive line clunks hard when I slow down to a stop. It's a very hard clunk. Not something to be ignored. I can drive the car without OD, but I'm worried it will break something.
By Dobie - 8 Years Ago
Does it clunk when you have the OD locked out? U-joint maybe?
The drive line does not clunk when the handle is pulled out. When the handle is pushed in, I suspect the overdrive is hanging up. There is a huge clunk in the drive line when you are slowing down to a stop with the OD engaged. I have the car on the lift right now while I rebuild the front suspension. After that, I'm pulling the engine and transmission to change the heads and cam. While I have the tranny out, I'll check the overdrive solenoid and see what's going on. The seals are leaking, so I'll fix that too. The car has a pretty low rear gear. 3,000 rpm in third at 55 mph. I'm going to need the OD if I ever drive on the freeway. The OD is a cool feature. I don't care for the freewheeling part.
You might find this helpful. http://www.oldcarmanualproject.com/manuals/trans/Borg-Warner%20Overdrive/index.htm It's the official Borg-Warner O/D service and operator's manual. Freewheeling can be a bit disconcerting until you get used to it. Best not to use the O/D in stop and go traffic and make sure your brakes are good. It shouldn't freewheel until your speed drops below the governor cut out speed, usually around 20 mph.
[quote][b]Florida_Phil (9/16/2017)"I don't care for the freewheeling part"
A famous race driver once pointed out...."brakes are cheaper than engines". Unless you live in mountainous country, engine braking isn't essential. Some people actually disable the governor so the car always freewheels.
I'm an old school hot rodder. I've driven many a muscle car and I much prefer manual transmissions. The fun of driving with a "stick shift" is feeling the engine in the throttle. The quick acceleration and engine braking you get with a manual transmission are much of the fun. I can see the need for OD as a way to reduce engine wear and save gas on the freeway. I can also see how a house wife would like it as she could leave it is 2nd and drive around town without shifting. This is the first OD car I have ever driven. Frankly, I'm disappointed. The actual performance is not up to the hype in my opinion. If I wanted an automatic, I would have bought one.
I think I would be a lot happier if I converted my OD over to an switch under the dash where I would only use it on the freeway. I don't drive my projects much and I can afford brakes and gas. I would consider swapping out the OD for a T5, but I don't want to butcher the car.
I'm not sure what performance hype you are referring to or what you expect? I've used OD trans in almost every early car I have owned since back in the 60's. My current 57 Ranchero and my 60 F100 have OD trans that I installed. The only performance advantage I know of is the ability to run a lower rear gear for around town driving and then using the OD on the hiway to lower rpms.
That is the performance Ford and the other brands that offered OD advertised, better gas mileage and less wear. Also the ability to shift without touching the clutch as long as you're below the governor cut in speed, generally 28 mph. I can see how the kickdown feature could be a little disappointing to someone who's used to driving an automatic. The OD kickdown doesn't have that "kick in the a$$" feeling because the OD is 30%, give or take. An automatic shifts down to 2nd or even low on kickdown. They get away with it because the axle ratios are tall. OD equipped cars have axle ratios ranging from 3:90 to 4:11 or even 4:56 for wagons.
My assumed hype of the Ford O/D comes from the fact that many high performance Ford cars previous to 1962 were O/D equipped. This makes sense as the low axle ratio would have raised their performance. I see now that there were other reasons for purchasing an O/D car other than performance. It never dawned on me that someone would care about gas mileage or brake wear on a hot flat head, 312 or 352. Not having to use the clutch to shift seemed even less of a feature. Having a low axle ration around town with an O/D function for highway driving is a very cool feature I intend to take advantage of.
One more question please. My '55 TBird has a top loader T-86 3 speed tranny. I understand this to be a light duty transmission. Does anyone here know if a T85 will swap into my car in place of the T86? If so, do I need a TBird specific transmission?
[quote][b]Florida_Phil (9/17/2017) The quick acceleration and engine braking you get with a manual transmission are much of the fun.
I agree. I especially like to wind it up in 2nd OD as I approach a wooded cove, and then listen to the glass pack music when I let off the throttle. But, you may discover very little 'fun' in having to replace worn syncros, throw-out bearings, etc. The best features of OD (aside from reduced wear & improved gas mileage) are instant kick-down acceleration without shifting, and the ability to avoid lugging the engine by pulling out of intersection turns in a lower gear after merely punching the throttle.
"One more question please. My '55 TBird has a top loader T-86 3 speed tranny. I understand this to be a light duty transmission. Does anyone here know if a T85 will swap into my car in place of the T86? If so, do I need a TBird specific transmission?"
I'm certain a T-85 will swap into your Bird, the '56 Birds had 'em and maybe some '55s. What I'm not certain of is if it needs to be specific to a Bird. I'm sure someone here will know, or you might contact Mac Van Pelt at Van Pelt sales. He'll know and he may even have one for sale.
By Sandbird - 8 Years Ago
I new of a person that put a t-85 in his 55 and found out the hard way that the transmission hump/tunnel is larger on the 56/57 Bird. He had to alter the floor pan to make it work. You may want to check this out for yourself.
Color me wrong...
By miker - 8 Years Ago
In 1968 I pulled a Fordo and put a T-85 O/D in a 55 bird. I didn't know it couldn't be done because of the smaller tunnel. It's very tight, and I think I had to cut a small notch in the top rail of the X member on one side. But only like 3/4". I used a Hurst synchro lok shifter, and that required some bracket changed to raise it up, and a pretty good cut in the top of the tunnel. The standard Hurst rectangular boot covered it ok.
If you're thinking of an O/D transmission as a 4 speed, I can see where you're disappointed. Think of it more as a 2 speed rear end. That said in today's world I'd replace the O/D with a T-5, which I did in my current 55 bird. I happen to like close ratios, and used the 2.95(?) low and the 0.80 5th. Most people use a higher 5th (I think it's like 0.67), and some the 3.27 or so 1st gear. Mummert has an adaptor that makes it easy, and brings the shifter out pretty close to stock.
Unless you put big tires on it and a lot more power, and hammer the hell out of it, the T-86 with the R-10 O/D will be fine. They went millions of miles behind y blocks and other engines. One thing that won't change with a T-85 is moving that heavy first gear when you shift. It's not like hitting second in a T-10 or other more modern transmissions that replaced it.
By slumlord444 - 8 Years Ago
I ran a T85 overdrive in my '57 Bird with the E carbs for a lot of years. The big advantage was that I could run a 4.10 rear end and still drive it on the highway. Floor it and hit the kick down switch at 65 mph and when it shifted down the dual quads opened up and all hell broke loose. Back of of it at 6 grand and shift into overdrive and keep going. Lots of fun. The toploader 4 speed I am runing now is more fun but sometimes I miss the overdrive.
Thanks for the replies. I had a bunch of Y block Fords back in the day and the weak link was always the three speed tranny. It always seemed to kill second gear at the worst time. Of course I drove like an idiot back then, so it's no wonder. I will not be drag racing this TBird, just driving around town. I do plan to hop up the 292 a little. I definitely don't want to cut the floor of this car. It's so perfect, God would smite me if I put a saw to it. I'm going to pull the motor and transmission soon and I'll check the O/D to see if it has a problem. If not, I'll probably seal it up and install an electric dash switch so I can switch it into O/D on the freeway. I am aware that starting out in O/D will kill the sun gear.
