Throttle Linkage
Home
Keeping The Dream Alive!
Technical
http://forums.y-blocksforever.com/Topic132133.aspx
Print Topic
Close Window
By Rudder2fly
8 Years Ago
What is the best linkage for 3-94 carb set up? I am working with a y-block with a Fordomatic.
By paul2748
8 Years Ago
Two places to try
http://vintagespeed.com/
Speedway
By Rudder2fly
8 Years Ago
I have looked at both places you mentioned. I bought the outboard carbs from Charlie Price. I was hoping for a recommendation from someone with this setup.
By Ted
8 Years Ago
Here are a couple of pictures of what I had for linkage for a 3X2 setup. The firewall or bell-crank linkage hooks to the bottom of the arm on the center carb.
By mrmike
8 Years Ago
Stromberg Carburetors 9245S - Stromberg TwoStep 3x2 Throttle Linkages
Compare
Throttle Linkage, TwoStep, Three 2-barrel, Stromberg, Kit Not Yet Reviewed
Part Number:
SBC-9245S
More Detail...
Estimated Ship Date:
Loading...
9/5/2017 (if ordered today) Loading...
$65.95
I bought mine from Summit racing years ago and don't remember the model # but they list this one for the Y-block. They also have a 9251 Pro listed for the Offy. I hooked my original linkage to the bottom center like Ted shows in the pic. I had to modify the original linkage rod from the bell crank to the Carb. I since removed all this & went to a cable linkage just running the center carb which works great fo me. Hope this helps!
By Rudder2fly
8 Years Ago
Thanks guys. I don't want to fabricate any linkage. So I have bit the bullet and ordered a Edelbrock 1033 set up from Jegs. What started out as a $300.00 purchase on Ebay about 10 years ago has now reached about $1300.00. It's only money right!
