By paul2748 - 8 Years Ago
56 Bird, 312, auto. While I didn't have a overheating problem, I have made some of the recommended things to keep it that way. I installed a wide mouth thermostat (NAPA #6) and put the plug in the bypass hose (with an 1/8 hole in it). The car runs at the usual mark on the temp gauge when fully warmed up, but I have noticed what I think is unusual. When first starting and the car warms up, the temp gauge goes all the way to hot. After 30 - 60 seconds the temperature comes down to its usual reading (thermostat opening). After that, even if I let the car sit for a number of hours the same day it usually works normal, regardless if the weather is warm or a little on the cool side.
I saw that another early Tbird owner on another site mentioned he had the same thing. The thermostat is new (I changed it when I first noticed this) and I checked the new one out with a thermometer in a pan of hot water before installing.
Question is - any one else noticed this situation after installing the plug in the by pass hose? Is it a TBird thing only?
This winter I planned to install the new spacer for TBirds and will probably remove the plug to test if the plug is the answer.
My 56 Victoria does exactly the same thing. Always that's slight panic after a couple of miles whether it will open and cool down, but it has never fails. Does it only when cold never on a second start up after sitting a few hours. I've thought it might be the thermostat hitting the heater valve screwed in right above it but probably not the problem. I am doubtful that the plug is doing it as some water is being bypassed and in many ways like the engine getting a little warmer right at the begining to help the oil warm up. I've lived with it for over 3 years.
By GREENBIRD56 - 8 Years Ago
The people at Stewart waterpumps - be sure and check for their web site - sell a modified Robertshaw style t-stat. The modification is three x 3/16 holes drilled through the stat so that it "leaks". This is for use with a fully blocked bypass (race engine)........ When the engine starts pumping water, the intention is that flow begins toward the t-stat and directly over the wax filled "pill" and gets it open and regulating.
I drilled my blocking plug (3/8 brass pipe plug) for the T-bird with another hole that I suppose provides a bit more initial flow - and mostly on the advice of Ted who says that the plug hole allows air out of the waterpump when the system becomes "static" (engine stopped).
It could be, if the thermostat is not drilled as Steve describes, that cavitation, and some other dynamic events are occurring to cause a spike in the temperature just before the thermostat is able to open fully.
This is what the Stewart Components modified thermostat looks like...... pretty easy to make the modification. It simply makes water on the top end of the engine migrate toward the "exit".
just waight you cooling engineers will see the results of no bypass. the holes in the stat is alowing water to circulate in the engine(by pass)replacement. temp rises as poor flow of water is heating as it enters the head.the cavitatin will creat hotspots and eventionly crack heads and other serious failures.also with temp sending unit at left rear of head not accurate especially withpoor flow.put on some miles and and use the engine on some good pulls you will see some issues.tho most users dont put enough miles for thes to develop. i do not know of any engine gas or diesel that does not have a bypass of some description to eliminate cavitation
I think the 3 x 3/16 holes in the T-stat have always been part of blocking off the bypass - some may not have read the whole discussion in past threads. Water has to migrate toward the t-stat to facilitate proper opening as the heads heat the top end of the engine. Try holding water in a bottle that has three such holes in it and you'll get an idea of the flow volume - though within our engines, an impeller is also pumping toward the opening.
If flow is stalled by complete blockage - the temp spike would be an obvious indication of no water movement.
By Gene Purser - 8 Years Ago
'Scuse my ignorance here, but does the bypass water flow toward the thermostat/intake manifold, or toward the water pump?
Gene - Water exits the block through the neck on the front of the intake manifold. The neck contains the t-stat - and below it a bypass port that fits into a 5/8 hose. That short hose directs water back into the suction side of the water pump. When the engine starts up cold, the t-stat is closed and all of the pump output is directed to exit through the bypass port - most likely causes an impeller inefficiency (designed in CAVITATION?) due to the restriction. Heated water leaving the heads into the intake (moving to the bypass port) gradually warms the t-stat and causes it to open.
Once the thermostat opens and begins to regulate - it maintains temperature control by speeding or slowing water that is exiting the block - headed into the radiator. A portion of the water is always bypassing the radiator (even if you are up near boiling) - and is being recycled into the block with no loss of temperature. This volume of water is what the modification is intended to redirect into the radiator.
When the modified t-stat is in place and water is restricted at the bypass port - water leaving the heads at start-up exits through the drilled thermostat. Modified as shown above - the heated water goes directly over the operational "pill" of the t-stat, and it begins regulate temperature by controlling the exit. No hot water (or very little) is sent directly back into the block. More - or larger holes may be possible if a different t-stat is used - but it could be set-up to have nearly the same restriction as the factory port.
Thanks Greenbird, I couldn't make up my mind if the 5/8" hose port on the water pump was pressure or suction. I see warnings against blocking the bypass. I have a 3/16" hole in a plug blocking the bypass and three holes drilled into the outer ring of the thermostat. Do you think I'm on solid ground? Thanks again for the detailed explanation Gene
the bypass keeps water circulating when stat closed,as it opens there is a transition to the rad. when stat open 99% os the water goes out stat threw upper hose and the water pump wont capitate threw the transition. ypass.most over heating is things other than the bypass. if therms wher to have holes i think they would be there. i sugest reading the principals of radiator cooling systems,cause and remedeys for over heating. race car guyes usually rebuild the engine frequently. unlike collector cars etc
By miker - 8 Years Ago
I had an off topic engine that did the same cycling on warm up. Aluminum heads with the temp sensor in the heads near the exhaust.
Showed over temp, then a drop, then overtemp, and finally settled down. I changed the stat, drilled holes, etc. Finally on day I noticed that if I turned the heater on it didn't happen. I installed a small #6AN bypass hose between the hot side of the intake to the water pump suction side. Problem gone. So at least some engines, when modified with the aluminum heads, needed the bypass when the stock ones with iron heads didn't.
On my bird, with the water pump spacer, I think the impeller is so inefficient at idle that cavitation from a restricted bypass isn't a problem. But with a good radiator/fan/shroud combo, I'm good at idle at 90 degrees.
The area of the bypass port is about .150 inches² - and the area of the three 3/16 holes is .083 inches² - so about 50% of original. Neither would be capable accepting full flow of the pump, so basically the impeller spins in the water ....... regardless. When the thermostat is closed, its similar to running a drill drive paint agitator - but not the kind of "CAVITATION" that engineers talk about.
When running with the modified system in the mode where the t-stat is closed and it is bleeding water through the three holes - the water entering the heads is coming up from the block and lower end of the radiator. So the thermal effects are going to be different from simply recycling hot water as the fluid has more heat absorbing capacity.
Restricting or blocking the bypass in not something that was invented by the Y-Block community. Stewart Components, a manufacturer of cooling system components is one manufacturer who does this and recommends it in some situations. You can read through their tech tips section. http://www.stewartcomponents.com/index.php?route=information/information&information_id=6
It might go against convention, but there are good reasons to do it. Like any modification, it is important that the person carrying it out understands the pros and cons and performs the modification correctly if it is decided that it will be beneficial. If that is done, then there will be no problems.
By Rono - 7 Years Ago
Thanks guys for your input. I tested my 160 degree T stat and it opens as it should. I think I will pass for now on modifying it, because it is not the same design as the one pictured. 160 works for me here in the summer at the edge of the desert in Idaho. Also, Mr. Gasket no longer makes the high flow thermostats. I checked on this at a distribution center for all the parts houses and that's what I was told.
By John Didde - 7 Years Ago
My 56 merc 312, i have a mopar long reach thermostat drilled 3 ea 3/16 holes in thermostat, plug bypass and drilled 1 ea 5/16 in by pass, works great, only problem at idle it will heat up a little at idle increase the speed of the a little and temp drops to previous temp , so i am installing a 5 inch pulley and 6 blade fan. the set up is working fine i am happy with setup
