By fabien13 - 8 Years Ago
 Je suis à la recherche d'une pompe à eau pour mon 239 ci, en effet, sur le mien, la roue est petite 3.74 "et sur la nouvelle la roue est plus grande 4.74" et les 4 fixations des vis sont totalement compensées, j'ai acheté 1 A Rockauto pour rien, c'était Néanmoins référencé pour le 239 ci. Je cherche une pompe à eau ou un kit de réfection, mais je ne trouve pas mon roulement d'axe de 0,63 ", le roulement est de 1,18" de large, je peux même passer ou raccourcir l'axe du palier avec un tour! ! Merci pour vos conseils. J'ai passé la voiture en 12V avec l'allumage électronique, super, le pare-soleil ... avant mais sans la pompe, je suis complètement bloqué! Je vous remercie
I am looking for a water pump for my 239 ci, indeed on mine the wheel is small and on the new the wheel is bigger and the 4 screws fixings are totally offset, I bought 1 A Rockauto for nothing, it was nevertheless referenced for the 239 ci. I am looking for either a water pump or a refection kit but I can not find my axis bearing made 0.63 ", the bearing is 1.18" wide, I can even pass or shorten the axis of the bearing with a turn! ! Thanks for your advices. I passed the car in 12V with electronic ignition, super, the sun visor top..j ahead but without the pump I am completely blocked !! Thank you
By Dobie - 8 Years Ago
Parts Geek shows 2 choices. The problem is your pump is a 1 year only part that went out of production 60 some years ago. Throw in part number consolidation and you may or may not get the correct pump. Your best bet may be to find a rebuilder in France and let them have a go at it.
http://www.partsgeek.com/mmparts/water_pump/ford/customline.html
Thank you guys, but I realize that it becomes impossible to find a pump, so I see 2 solutions, either I re-roll if I find, or I change the timing chain cover so I can put a pump back more easily!!!!
Replacing the timing cover is the best decision in the long term. You will also need to replace the fuel pump if you do that.
By pintoplumber - 8 Years Ago
There's a guy on the Ford truck enthusiest 48-56 site that has a 239 car water pump. I left a message for him over there. Hopefully it works out.
Oh, would be wonderful, I had another and I wanted to please a woman in denmark, I did not think it would be so difficult to find !!! I saw a kit on Vanpelt sales llc, I contacted them, I hope !! Thanks a lot to you guys, it's very cool...see you , thank you !!!
