By Larry H - 8 Years Ago
I need an adapter for a Y-Block valve cover to fit a SBC. Anyone know anyone that makes them ? Thanks, Larry
By miker - 8 Years Ago
Well, most of us don't need an "adapter", our valve covers bolt up just fine.
Start here, and make your own. Interesting that the scrubby is an engine that needs to be disguised. You'll need an "air gap" manifold too.
http://www.jegs.com/p/JEGS-Performance-Products/JEGS-Small-Block-scruby-Centerbolt-to-Early-Style-Valve-Cover-Adapters/757463/10002/-1
By paul2748 - 8 Years Ago
I've seen them for a small block Ford, but for for a scrub. Put a set of those fake Olds ones if you cannot find one for a YBlock cover
By slumlord444 - 8 Years Ago
You just need a Y Block engine and it will fit fine.
By 62bigwindow - 8 Years Ago
Ditto. And alot cooler.
By oldcarmark - 8 Years Ago
You guys aren't very nice to this Man. He obviously really wants to be a Y-Block owner but just can't quite take that Step and join us.He wants to try it out first and see if it feels comfortable. One Day He will see the Light. In the meantime We should do our best to encourage Him.
Funny his only post is to make his scrubby something it isn't....
By Rowen - 8 Years Ago
Hummmmm,....now if he can only disguise the intake..,,,,,,,,!?!
By dbird - 8 Years Ago
I guess you could use a universal joint to angle the distributor.
Dbird
By Baby Blue 57 - 8 Years Ago
Come on guys why be so negative to some one that wants to be creative! Get off your high horses and help a fellow Hot rodder! Stop drinking the Cool Aid!! It doesn't matter what he's trying to accomplish it's the knowledge we have all gained to help a fellow Hot Rodder period!!! and point our fellow friend in the right direction with help not with negativity and bias opions. I can't believe some of the remarks that you guys say on here!!!! Help this Guy to keep our love of what we do, at every cruise I go to we all help one another regardless of what they drive! I've seen guys leave because they have been snubbbed by fellow Hot Rodder's Too high and mighty!!! Remember you once where there at one point! Help your fellow man with knowledge not criticism!
I hate to point out the obvious but this is a site for y block engines not a cookie cutter small block scrubby. There are a million other places to look up info about them. I think the comments reflect that. If the guy wants to know how to put a real y block in his ride then we are happy to help.
I think the posted Comments are quite Tame compared to what would be said if the situation were reversed and someone asked this Question on One of "their" Sites? I think they would be unprintable!
By Ted - 8 Years Ago
Seeing as how the aftermarket is making a surplus of Y covers, I’m more than happy to see them put to other uses. I’ve seen 348/409 covers on a Ford Y so that valve cover swap or interchange works both ways. In that vein of thought, I’m not aware of any company making the specific adapter you require but doing some searching on Google or the HAMB might give you some leads. Here are a couple of links that will get you started in the right direction. http://www.fastlanerodshop.com/5window/5window_valve_covers.htm http://www.hotrod.com/articles/1212cct-classic-y-block-covers/
Thanks Ted 2 great articles. A friend of mine bought a custom 56 Vic with a 351 and has bought a set of those adapters for it. The FE T-Birds looked great on the Windsor. I don't mind keeping with the same brand and always liked the 56 Continental covers.
By CSPIDY - 8 Years Ago
the OP has only had one post and one visit, didn't even check for replies.
