AES GEAR REDUCTION STARTER
http://forums.y-blocksforever.com/Topic129577.aspx
By rontron - 8 Years Ago
Looking for reviews of the AES gear reduction STARTER for my 292 so as to make a decisions whether or not to change out the stock starter.......which is heavy and sounds like an old cluncker when you turn it over...........I also need to say I have the fordomatic not a stick shift
I've had one for probably 15 years now, possibly over 25K miles, driven year round, without a single problem.
Thanks Charlie, did you pay anything close to the price they are charging now...........239.00?
I noticed Charlie you have a 3 speed..........I need some feedback from someone who has one with a Fordomatic...........auto tranny
The transmission does not matter.  I think I paid $129, but like I said, probably 15 years ago so what I paid is irrelevant now.
I have a 5 spd.  Where'd you see 3 speed?
I clicked on the picture of your truck and your profile came up and that's where I saw three speed.......
Isn't the flywheel number of teeth number a different count on the auto vs standard tranny?
By aussiebill - 8 Years Ago
rontron (4/1/2017)
yes, but standard starters didnt change gears.
rontron (4/1/2017)
Oh, indeed it does.  That info is way out of date, probably also from about 15 years ago.  I'll need to update.
By pegleg - 8 Years Ago
I'll second what Charlie said. Mine's the same age, never a problem. I've used it on a 3 speed manual and an automatic without any problems for 12-13 years.
By Kahuna - 8 Years Ago
Who sells the AES starter
AES sell the AES starter:
http://www.autoelec.com/
Thanks. I've often wondered about the use of 2 cap screws instead of 3 and the gear running off the front of the ring gear instead of the back side also.
Again, no problems in about 15 years, on a daily, year round driver.
By paul2748 - 8 Years Ago
I have a mini starter, (not sure it's the same brand) that is held on by two bolts with no problems.  been on over ten years.
DryLakesRacer (4/5/2017)
AES
