By MoonShadow - 9 Years Ago
Some time ago there was a post for the part numbers of the brake hoses to fit a 55/56 Ford brake line to Granada/Versailles disc brakes. Does anyone have that info?
Someone, anyone?
By paul2748 - 9 Years Ago
I did the Granada swap in my 54 - should be the same for a 55. Used stainless braided line. Here are the part no's:
Hose # 3 X16 inch braided steel line (Either Summit or Jegs has them - DOT) Check for length in your application. Earl Adapter # 989543 AN3 to 3/8-24 (3/16 brake line) Earl banjo # 997634 7/16 Earl Banjo Bolt # 977522 7/14-24
Thanks Paul. Braided lines are fine. I sold my disk setup to a friend with a 55 but couldn't find the brake hose listing. There was also one on here for the standard rubber hoses. I'll forward this to him.
By oldcarmark - 9 Years Ago
1974 Mustang/ Pinto are the OEM Hoses that I used for this Conversion on my 56.
