By Rowen - 8 Years Ago
So over on the 57 ford site there is/was a discussion about boring y-blocks. As I understood one response, you can take a 272, simply bore it out to 292 specs and like magic, you have a 292. Is this correct? 272 crank and rods are the same? If this is so, it would be GREAT news for the little 272 blocks laying around EVERYWHERE!! Doesn't sound right, but what do I know......
Ok, a little research on johns y-block site and my question needn't have been asked. He says that very thing in print!! Guess as long as I learn something every day all is not wasted!! Hummm, the possibilities......
By mrmike - 8 Years Ago
This is interesting because my engine in my merc is a 55 - 272c.i. bored out to 292c.i. rebuilt by NAPA in Pennsylvania. I have the paperwork on it. I bought it from a guy down there that had it rebuilt for his 55 ford & then decided to go with a late model conversion. Mike
By MoonShadow - 8 Years Ago
A good 272 block can go way past 292. Depends on a sonic check to be sure how far.
By NoShortcuts - 8 Years Ago
The article identified below appeared in The July-August issue of Y-Block Magazine in 2014.
It is written by Ted Eaton and documents what might be done in re-purposing an original 272 for significant performance output.
While the write-up is more than merely boring the cylinders to 292 specs, it illustrates what else could be employed to increase the engine's original performance, horsepower & torque output. My understanding is that 272 pistons are becoming scarce while 292 pistons are still readily available.
Keep in mind that Ted lays out a buffet of improvements that you could employ.
Boring the cylinders, using an appropriate performance camshaft, using stock 1.54:1 rocker arms, a set of G or 113 heads, zero decking the block for the pistons, changing to a stock 'B' intake manifold, using a later stock combination centrifugal & vacuum advance distributor, AND having the rotating assembly balanced will t-r-a-n-s-f-o-r-m your engine's performance without sacrificing drive-ability, reliability, or your wallet.
Here's a link to the article mentioned above on Ted's web site... http://www.eatonbalancing.com/blog/2015/06/05/hopping-up-the-272/
Not to confuse the situation, but for my purposes I'm leaning toward using the cam Ted used in building an engine for Karol Miller in 2015. I think that the cam's 110 degree LSA will serve me better for city stop-and-go and lower rpm throttle response
Here's a link to Ted's article on building the engine for Karol's '56 Ford... http://www.eatonbalancing.com/blog/2015/05/01/unported-iron-heads-can-still-make-over-a-hp-to-the-cubic-inch/
Food for thought!
Thanks for all the responses guys!! Once again I find myself with options I didn't know I had. It's nice to know that just in case my current 312 block doesn't work out (has not been sonic checked by me), I have another option. As long as my 312 crank is ok (has not been checked by me), I can still build that stroker im looking for. Current 312 block has been sleeved down to 292 bore. That's how it was when I bought it. Supposed to have been quite a bit of work done to it. I will have it all checked out before assembly. I LIVE THIS SITE!! Thanks again....
Rowen. Yes, someone did some serious work on the 312 block you've got. There's nothing cheap about having 8 cylinders sleeved and the new pistons fit!
Well sir, that's what I'm hoping for after crack testing both block and crank. I feel comfortable with the purchase since it came loaded with Mummert internals. I am new to the y-block since the purchase of the Crown. It's the beauty of the car that I ALWAYS loved as a kid knowing nothing of the drive train. Now it's the rare nature of the first gen overhead valve ford. I look for them at every show I go to and maybe will find one other in a early coup or roadster. Just knowing that I will be one of the few hot rod y-blocks when I bring her, makes me smile!😊 Most folks have no idea what they are looking at when I open the hood, and with all the VERY VALUABLE information I glean pretty much daily, (frequent visitor), I am able to tell them what is other than, "no, it's not a sbc." "But fords have the distributor in the front!?!" Makes em scratch their heads. 6v pos grnd makes em say "huh?" As well. Sorry for the long post, 15 mos out till I retire, and I'm really looking forward to this project. Have a great evening fellas and thanks for the tutoring.
By aussiebill - 8 Years Ago
Boreing 272 to 292 has been done for past 50 yrs or more, no mysterys.
By LordMrFord - 8 Years Ago
I think latest dragster's block is overbored 272 to 3.78" and still holding hundreds of horses inside with 34 psi boost , so N/A street engine might be quite reliable.
