By Outlaw56 - 8 Years Ago
Is there a good aftermarket source for y block oil pans?
No. Only used, originals.
They got to be betting a little hard to come by.
No, pretty easy. There is usually several on eBay. If you have a good salvage yard within a couple hours drive, you can probably find some there. As long as they have not been crushed or pierced, they're usually in good condition. Since it's the lowest part of the engine, they are usually coated in a protective coating of oily grime.
One thing you should do is email or call the major manufacturers, Moroso, Milodon, Canton, etc. to ask about it. None of them will have one and unless you're willing to spend a lot of money, none of them will build one for you but the more requests they get, the more likely it is that they will produce one.
By NoShortcuts - 8 Years Ago
Charlie's correct regarding eBay. Usually there are several y-block oil pans available. In checking this evening there are two (2) passenger car front sump units available, but no rear sump truck units listed. To check on eBay, use the SEARCH box at the top of the page and just enter, 'Ford y-block oil pan'. Be sure to look at what they're going to charge for shipping. A few weeks ago someone had a rear sump pan on for $10, BUT had $50 listed for shipping cost from CA to NY. I questioned the seller on it, but he claimed that's what FedEx was going to charge! Ouch!
Hope this helps.
However, I would say a total of $60 is not bad at all for a pan that cannot be had just anywhere.
$50 for something that big, to the opposite side of the country is probably about right. It's the size, not the weight.
By slumlord444 - 8 Years Ago
Shipping on large items gets expensive. Shipped a NOS '57 T-Bird quarter pannel to New York once. Cost a bit more than I had estimated.
By repeater - 8 Years Ago
I have an additional rear sump truck pan that is not a "stepped" pan, it's a true rear-sump. Has the baffle and pickup still attached. Let me know if you're interested. I also have an NOS, never installed rear sump "stepped" pan, with no baffle, but I'm currently using it for mock-up fabrication right now. I may or may not use it.
All truck pans are "stepped." The 6 quart pan steps down twice. The 7 quart pan steps down once. Both are more or less wedge shaped. Which one do you have?
Terminology I guess. The NOS one is the 2-step one. I have a used 1 step rear sump pan, with pickup.
Any suggestions on what is the best oil pan to use for a Y block 56 Ford F-100 with dropped front axel 3" (raised back up 2" with leaf block spacers), 3" lowering leaf springs, AOD Conversion, and Toyota Power Steering?
For street use, any truck pan and pickup combo will do the job. Add a baffle, if the pan does not already have one, to prevent oil from rushing forward while braking. For performance use, a baffled truck pan with the rear positioned pickup or, if it will fit, a T-Bird pan and pickup.
I guess with the Transdapt yblock motor mount I ordered from Jegs, Im committed to finding a front sump car oil pan. The instructions that came with the mount specify a yblock oil pan out of a car, not a truck. UGH!
Will a car pan clear the axle?
Surely they don't actually make a mount for swapping a Y into anything, let alone a truck that came with one. I'm not finding that on their website if they do. So, since it is not actually for a Y, any instructions specific to engine fitment are useless. Can you bolt it to a block and check? Maybe a rear sump pan will work. For that matter, maybe a car oil pan will not.
If you do need a car pan, you will also need to get a dipstick and tube. Mummert probably has stainless tubes. I also see originals on eBay regularly. Dipsticks are a little harder to find, though.
Thanks for the response Charlie. I am about to head out to the shop and look at the mount now. The mount includes the stock Yblock motor mounts, so yes I believe the motor mount is intended for adapting Y blocks into anything with a 28" frame rails. I did try it in the frame rails ahead of the engine and its a perfect fit. I will check on the axel clearance question. Meanwhile, I am looking for an oil pan from a car to include a pick up tube. Any leads appreciated. I have a post on sell and trade. I did not realize this swap would require a new dip stick and different location, but I get it. If you swap ends on the oil resivoir, only makes sense you have to swap the dip stick too. Im assuming there is a location in the stock block that will allow moving the dip stick from the rear of the engine to the front of the engine? Ill be looking for that as well. So a truck and car both use the same oil pump off the distributer but a car has a longer pickup tube than a truck because the oil resivoir is further away? Is it possible to fabricate a longer tube using a truck pump and pickup?
The only swap cross members I see are for FE, and the mounts will be similar, if not exactly the same. Since it is for an FE, the instructions are for an FE. It also calls for a 4 quart front sump pan, again for an FE so not necessarily applicable in this case but a car will be 5 quart, so potentially a lot of problems to overcome there.
There is a hole in the block for the car dipstick tube. It's in front of the cylinder bank, just before the timing cover. You can't move the truck dipstick tube as it is entirely wrong to fit, but a correct car tube will fit.
You can modify a truck pickup to fit a car, but it should not be hard to come up with a proper car pan and tube.
There are car pans and a dipstick and tube on eBay right now.
Have you considered this truck mount? http://www.ebay.com/itm/1955-1956-1957-1958-Y-BLOCK-V8-292-F100-F600-ENGINE-FRONT-MOTOR-MOUNT-/252771375664?hash=item3ada591a30:g:YGQAAOSwdGFYo7UQ&vxp=mtr
Well, changing the oil pan, pick up and tube, dip stick and the potential of more problems using 3" dropped Posie leaf springs, I bailed on using the FE Adaptor. Jegs was great and returned with free shipping. Now Im back to square one. I bought the F-600 Motor mount posted by Charlie. It looks like its much more stable that the front stock motor mount in an F-100. I just hope the F-100 and F-600 front cross members are the same. Otherwise, back to the drawing board.
If an F-600 front motor mount works, it will definitely provide considerable more stability than the F-100 stock front mount. Problem is, its a long ways back to the next mounting location which is on the end of the AOD Tailshaft. I had purchased a set of Thunderbird "stabilizers" that mount stock mid Yblock motor mounts. I can use them and if they are not enough, I will be fabricating my own mid block motor mounts using stock motor mounts and fabricated mounts to frame rails on both sides. Changing oil pans includes dipstick, pick up, pick up tube, oil pan, and then hurdle of clearance with front axel.
That mount is also used on F100 but I don't know the exact applications. It should be fairly easy to make that work but it probably will require some custom brackets and welding.
Thanks Charlie, its worth $40 to give it a try. I paid $159 for the mount for the FE engine so Im ahead of the game when you consider all the issues associated with changing oil pans and potential clearance issues. Im starting to mock up mid block frame rail mounts for stock yblock motor mounts and just fabricating my own. Im a serious wood worker so I can mock up everything with wood and get a perfect pattern before I make steel ones. I would sure like to drop the engine 1" to get a little cab clearance over the bell on the AOD but not sure how much trouble that would lead to down the road. To me, modifying the cab floor/firewall for AOD means no custom carpet and a floor hump. Either way, its a modification that leads to something else, lol. I may have a F-600 mount for sale, although the guy gives refund within 14 days and pays return shipping. If I dont use it, I may ask him for a refund but I will pay the shipping.
This is the little puppy I am trying to find out where to locate motor mounts and photos or diagrams of how it mounts to the cross member.
