By flatbill - 9 Years Ago
Hi all. This is my first post and hope the members can help me. I am working on a 368 inch Y block from a 1957 Mercury Turnpike cruiser. I have read that the hydraulic lifters from the FE 390 engine will also work in my project. Can anyone confirm this?
On the front of the camshaft there is a sleeve that spins on the fuel pump eccentric to push the pushrod. Its about 3 inches in diameter. The one I have is very pitted with rust on the outside and I have not been able to find a replacement. Any source for this or is it used on any other engines from Ford?
My last question is about the 2 brass plugs that close off the oil galleries at the front in the timing cover area. The machine shop destroyed them taking them out and didn't same the pieces. I think that these plugs have an oil hole in them to lubricate the timing chain. Can anyone confirm these holes and/or the hole diameter? Were both plugs drilled? Does anyone know of a source of these? Were these used on the 312?
By Ted - 9 Years Ago
Welcome to the site. 390 lifters will work. I’m not real familiar with the LYB family of engines but you might look at the fuel pump concentrics for the FE (390) and 385 (460) Ford families. I suspect one of those will work. Regarding the oil galley plugs in the front of the block, just get the size of the hole and any competent machine shop should be able to supply a plug that will work. It doesn’t necessarily need to be brass and the need for an air bleed hole in one or both is debatable. My druthers would be to tap the holes the appropriate NPT thread and install real threaded plugs in those holes. If one of those plugs is directly in line with the distributor gear, then drilling a 1/16” or smaller hole will throw some extra oil on the distributor gear itself.
Thanks for your reply. I have ordered the 390 lifters for the motor.
The plugs are located in the front of the motor and are threaded 1/4 inch tapered pipe thread. I have some brass plugs that will fit but wanted to find the size of the squirt holes. Does anyone know if the FE or 385 motors have the fuel pump eccentric sleeve on the front of the cam? I think the holes send oil to the timing chain.
The later model 460’s have the two piece fuel pump concentrics. If your engine already has a two piece concentric, I suspect it’s been added as the two piece concentrics came out on the Ford engines in the Seventies. I’ve no problem with the earlier model single piece fuel pump concentric that came out on the FE, SBF, and 460 engines but you’ll need to make sure you are using the one with the correct hole size for the camshaft retention. The Fe fuel pump concentric uses a 7/16” bolt while the SBF uses the 3/8” bolt. Seems like I’ve been both bolt sizes on the 460 engines. If you can post a picture of what you have along with the camshaft retention bolt size, that will help in determining if there is a another engine family fuel pump concentric that will work.
The fuel pump eccentric is cast as a part of the camshaft snout. There is then a sleeve that runs on the OD of the eccentric between the camshaft and the fuel pump pushrod. The sleeve is about 3 inches OD and maybe 3/32 inch thick. It rides between a flange that is part of the front end of the cam and the timing gear.
 I should be getting the cam back from the regrinders today. I'll add a pic of the cam. Here are some pics of the sleeve. You can see why I would like to get another one. Thanks, Bill
I now have a used replacement for the cam/fuel pump ring and lifters for a 390.
Billk
A 368 is a Lincoln Y Block.
By Lord Gaga - 9 Years Ago
An FE (Ford, Edsel) is also a Y block. Lord Gaga's Believe it or Don't ! Also, Dumbbells are not bells nor are they dumb!
By martyk98 - 9 Years Ago
My apologies. Never considered a 368 a "true" Y block when I talked to my T Bird friends. Ref the 390 lifter question, does this make my old 368 roller lifters a rare item or are they available also?
martyk98 (9/7/2017)
.......Ref the 390 lifter question, does this make my old 368 roller lifters a rare item or are they available also? The roller lifters for a 368 LYB are expected to be interchangeable with FE engines so probably not a rare item. A roller camshaft for a 368 would be a novelty though.
By KULTULZ - 8 Years Ago
flatbill (1/5/2017) ...the 2 brass plugs that close off the oil galleries at the front in the timing cover area. The machine shop destroyed them taking them out and didn't same the pieces. I think that these plugs have an oil hole in them to lubricate the timing chain. Can anyone confirm these holes and/or the hole diameter? Were both plugs drilled?
I know this is late but it may help someone else down the line.. . Yes, the plugs (threaded fittings)are drilled. They are similar in appearance to carb jets. The fuel pump eccentric is unique in that it is actually mounted over the cam snout. The pump is actuated by a driving rod similar to a MEL or SBC.
LYB roller lifters?
Edited 6 minutes ago by Ted
THANX TED!
What am I doing wrong? I have made this mistake more than once...
By Ted - 8 Years Ago
KULTULZ (4/8/2018) Edited
6 minutes ago by Ted THANX TED! What am I doing wrong? I have made this mistake more than once... Don’t know why but your replies ends up being within the quote box. Sort of makes it hard to read on my end. I’m simply going into the post and closing up the gaps around the ‘quote’ markers. You might try putting a hard return after the quote itself when replying and see if that helps.
Again THANX!
It may be my browser...
By martyk98 - 7 Years Ago
Hey Ted, just going through some old postings here ref 368 engines. I'm going to tackle one and still looking to put roller lifters/cam in mine just cuz I can. From what I've read the only difference between a stock 368 Lincoln and the M335 is carburation. Your thoughts?
By Oldmics - 7 Years Ago
M335 used the two Hollys as you have already ascertained. Used a tach drive dual point distributor. Heads were cut .060 to raise compression and had a pretty radical camshaft using solid lifters.
It was a blueprinted engine assembly.
Dont forget those unique looking valve covers. I have repro air filters for the M335 carbs if interested.
Oldmics
By KULTULZ - 7 Years Ago
