By geo56 - 10 Years Ago
I hope someone on here has corrected a similar problem to mine because I am stumped. I have a 56 Victoria that I have driven regularly for three years. Lately, when I put on the right turn signal the right rear taillight blinks. However, the tag light blinks with it and the left tailight also blinks faintly. When I put on the left turn signal, the left rear blinks as it should and the right rear light and tag light don't blink. Through all of this, the front parklamps blink correctly. On top of all this, when I depress my brake pedal, I notice that the speedometer part of my gauge cluster lights up and goes out when the brake pedal comes up. So far I have replaced the turn signal switch with a NOS FoMoCo switch that did not solve the problem. I dropped the headlight switch down and examined it and around it for obvious burnt or shorted wires. I hate to throw more money at it and hope someone can help me with advice. Also, a thank you to Ted Eaton who removed the glitch that kept me from posting on this site.
By shakey - 10 Years Ago
check all your lites for a good ground shakey
I shined up a spot on the rear of the frame and ran jumper wires that I connected to a mounting stud on each tail light and connected the other ends to the frame. I also ran a jumper wire from a mounting screw on the tag light to the same spot on the frame. It didn't solve the problem.
By paul2748 - 10 Years Ago
Did you try grounding the front parking lights?
They are blinking just fine and I did not think of running an augzillary ground from them. Now that you mention it, when I built this car several years I replaced the front parklamp sockets and wiring assemblies with reproduction units. When I installed the new parklamp sockets into the holes in the potmetal parklamp castings, they were a very loose fit in the holes. To make a tighter fit, I stripped some copper wiring that I had and wound some around the new sockets to make them fit tighter in the holes. Being that the parklamp housings are pot metal, should I try to run a jumper wire from the rear of the parklamp sockets to a metal part of the front clip? Did I also mention that when I depress my brake pedal, the light inside my speedometer gauge lights up?
By lowrider - 10 Years Ago
Check the rear bulbs. Usually when one filament breaks off and lays against the other It will cause the problem your describing.
By Meandean - 10 Years Ago
I had similar problems when I had one of my rear tail/brake light connectors wired backwards. Probably not your issue, but thought I'd mention it just in case you had done any rewiring to the fixtures.
Dan You nailed it! I pulled out the right rear taillight bulb and couldn't see where it was obviously burnt. I tried a different bulb anyway and the problem was solved. My speedometer guage light has even quit flashing when I put on the brakes. Thanks
By Talkwrench - 10 Years Ago
Dan the man!
I bought halogens at an Auto Zone and they are a lot better than 1157's and did not affect the turn signals.
By Dobie - 9 Years Ago
SPAM
More spam
By oldcarmark - 9 Years Ago
More Spam. These Guys need to get a Life!
By Dobie - 8 Years Ago
SPAM...
By Lord Gaga - 8 Years Ago
A 400 lb russian hacker probably...we'd better tell jeff sessions!!!
More SPAM
By Evelynfruth - 8 Years Ago
If you see a Spam message, never, never, never click on their links.
Please give the moderators at least 24 hours to delete SPAM messages. The moderators typically check for Spam on a daily basis and once spotted, it's typically cleared out in a timely fashion. The IP addresses of the Spammers are blocked accordingly so they can not post new messages. The Spam message in this case has been deleted but the Spammers' post itself has been left in place simply to post this message. For reasons not clear, this particular post does attract the Spammers on almost a daily basis. The other target for Spam on this site is the 'Aftermarket Parts' section as it is not posted to on a frequent basis and the Spammers seem to think they can slip the Spam messages in place without being noticed. Wrong! Because this site does not require a background check for new members, this site does attract its share of Spammers. It's much easier to deal with the Spammers than do the background checks for new members which would require constant attention to approve / disapprove members on a daily basis. New members can post almost immediately after registering for membership which is the preferred way of getting new legitimate members posting to the threads right away.
Yet more spam...
