Y Block push rods
http://forums.y-blocksforever.com/Topic126963.aspx
By Pops57 - 10 Years Ago
Hello Y'ers. I have one push rod that fell out. Apparently that one pushrod is bigger than all of the other pushrods. Why would this be? How would this effect the engine?
By Ted - 10 Years Ago
The pushrod being larger than the others suggests that it had been replaced in the past.  Could be a tubular pushrod while the existing pushrods may be the smaller solid stem style.
There are a variety of reasons for a pushrod getting loose.  Some of these include:
Too long a bolt is installed in the end holes in the cylinder head thus hitting the pushrod
Pushrod is contacting the head within the pushrod hole
Rocker adjustment not staying put
Camshaft/tappet wear
Over-reving the engine
Valve springs weak
Worn cup in pushrod
Lack of oil to topend
Worn rocker and/or rocker shaft
Once the reason for the dislodged pushrod is determined, simply correct and replace the pushrod.
