Way to go Ted
http://forums.y-blocksforever.com/Topic126382.aspx
By dbird - 9 Years Ago
Must have been a drag to be within 3 hp of 600 and not get it.   Congrats, Don
http://www.hotrod.com/articles/ford-y-block-takes-vintage-class-win-engine-masters-2016/?wc_mid=4035:3686&wc_rid=4035:2095963&_wcsid=3FF6072707AE87D744769C305D4293F1BC23522747DBB10E
By MplsMike - 9 Years Ago
Are all of the results posted somewhere? I can't find them.
By 62bigwindow - 9 Years Ago
Congrats Ted!
Official results are not yet posted.  Hot Rod aren't reporting on it as much as they did last year.
By speedpro56 - 9 Years Ago
Hope it's not the kickass Yblocks holding them back as it did in bygone years!
By Sanddoc - 9 Years Ago
IC a 404 ci Cleveland won small block
By Vic Correnti - 9 Years Ago
A big congratulation goes out to Ted, John, Geoff and Royce for keeping the dream alive!
 I am thinking the small block Ford is a Windsor with Cleveland heads. They will have to give the LS it's own class next year so they don't have to compete with Ford so they can win.
Congrats Ted, and the gang.
  Vic you could be correct, there was not a lot of detail on the Hot Rod website, when I read it
By Daniel Jessup - 9 Years Ago
Kudos Ted.
I will be looking for the HOT Rod Magazine Issue that covers the event.
By Ted - 9 Years Ago
Thanks for the kudos guys.  Being the second engine to run in the class, it left the remaining competitors a target to shoot for and knowing how many points they needed in which to beat the 2785 points my engine put up on the board.  My score did manage to hold up to the end for a first place finish.
I actually made 603.2 HP on the last pull but didn’t use that sheet for the scoring.  I’m in the process of contacting the right people on the HR website to get that peak HP number corrected.  Here’s the sheet of the last pull made which did exceed the 600 HP number at 6500 rpms.  A good HP number on that pull but score suffered due to trading torque for horsepower.
http://forums.y-blocksforever.com/uploads/images/d827566e-86dc-41d4-8cfd-d0ed.jpg
By Cliff - 9 Years Ago
Great, Ted did you flow the heads? if so can you give us a hint?
By Y block Billy - 9 Years Ago
Did you make any changes to get the higher numbers? I.E. jets, timing etc. or were you happy and just made back to back pulls withjout changes?
By Bobwanna - 9 Years Ago
Ted, congratulations to you and the gang for another stellar performer proving the Y-block is a winner  - and it looks great! - Bob
Cliff (10/9/2016)
Flow numbers will tend to vary from one flow bench to another so the numbers may not be applicable when comparing heads tested  on different flow benches.  With that being said, this year’s 2016 EMC Y heads are flowing in the neighborhood of 290/275 at 0.650” on the intakes and 186/194 at the same lift on the exhausts.  Not bad at all for small valved heads.
Y block Billy (10/17/2016)
Team Eaton made a total of 10 pulls in a 35 minute span.  Optimum ignition timing was figured out at the shop and was simply verified upon cranking the engine up on the UNOH dyno.  There were jet changes made during the 35 minute time period and one of those jet changes was made addressing a lean condition that ultimately was the result of a linkage problem with the sideways mounted Holleys.  Changing eight jets instead of four does take some coordination to do it in record time.  To their credit, this was discussed and rehearsed in detail prior to putting the engine on the dyno.  The team members proved their worth in how easy they made the jet changes look.
The highest horsepower pull did come at run #10 but that particular pull had a lower score than three of the other pulls that was used for scoring.  The peak numbers were not as important as having a broad range of simply good numbers in which to average.  In essence, we were trading HP numbers for TQ numbers to up the score.
