Y me (9/20/2016)
Ok. I checked the bolt and it isn't hitting, I ordered new push rod . The original problem I'm after is oil fouled plug #7. I vacuum tested and I get steady reading of 21 and when throttle is opened it go's to around 5 and shoots back up to 25 settling back to 21. It smokes from left pipe only. No smoke at start up, after about 2 min light smoke at idle. Moderate smoke at idle after spirited driving. I'm waiting for compression and leak down gauge I ordered . Also no noticeable pressure from oil fill, Any ideas? Thanks
Compression test and/or leak down test will give you a good idea where the oil problem lies. One of the worse case scenarios would be a broken compression ring.
