Carpet
http://forums.y-blocksforever.com/Topic125804.aspx
By 55 GLASS TOP - 9 Years Ago
Hello I want to put a new carpet in my car , I would also like to put Dyna-mat down can someone advise if I still need to put jute down under the carpet. I assume it all gets glued down. thanks for any reply.
By miker - 9 Years Ago
If you google "peel and seal", it will come up at all the big box stores, and half a dozen or more car sites. I've got 2 cars with dynamat, and I've done 2 more with this kind of product. Pretty much the same, but way cheaper. Clean the floor good, and roll it down with a Formica roller, like a countertop. A search here or the Ford barn will also come up with it, and a lot of uses for various foil products. I like to use foam carpet mat in place of jute, it's not as messy. Doesn't seem to be a heat problem with the foam with the foil product down first.
I had a couple glued carpets that ripped the pile right thru them when glued, so I just use some double back tape only where I have to now.
You'll see a big difference in noise and heat.
By ian57tbird - 9 Years Ago
Don't glue. As miker said, it will ruin the carpet if you will ever need to lift it again. Gravity holds mine in just fine.
