Did a search but did not find what I needed. I need to replace the front shocks on my 56 Victoria. What I find are pin type on each end. My bottom mounts are cross pin thru the ring with 2 cap screws. Any suggestions? I'm open to any name brand and have good luck with Monroes, Gabs, & KYB's. If you have #'s that would be great. Thanks.
By Genuinerod - 9 Years Ago
Your lower "A" arm should have a front shock absorber mounting plate (p/n 18072) that receives the pin type shock absorber. This item is sold in T-Bird catalogs for about $14.00. All 54,55,56, full size cars and little T-Birds use the same parts.
Thanks. Looks like someone found a different style to fit. You just new know what you will find.
