Fan Shroud
http://forums.y-blocksforever.com/Topic124437.aspx
By Kahuna - 9 Years Ago
Has anyone installed a fan shroud on a 56 Ford?
Is or was one available new?
Any good aftermarket ones available?
Any one that someone would recommend?
Jim
If you are having cooling issues, particularly at idle and low rpm, try a smaller diameter water pump pulley.  That will speed up the pump and actually move some coolant through.  If you observe the flow with the stock pulley, it's not usually more than a trickle, which keeps coolant in the engine too long, absorbing heat.  Even on more or less stock engines, that has been a problem.
Thanks Charlie
I'm adding AC so thought this might be a good idea
Jim
By paul2748 - 9 Years Ago
If you haven't one on now, try a 6 blade fan.
By miker - 9 Years Ago
I agree with all the above.
You might go see some of Greenbird56's post. Along with the Hayden fan clutch, the big fan, and the restricter he suggests, a good shroud really helps. The A/C unit will probably have an electric fan for the condenser. This cuts down flow to the radiator. I'm running a really tight shroud and electric fan for cooling, and the little fan on the condenser. Doing it again, I'd run the Hayden unit, a good fan, and the shroud. I bought a Classic Auto Air unit, and I think the Vintage air does a better job on the condenser and its fan. As it is, with the A/C on, stopped, the fan runs a 90-120 second cycle on a 90* day. But my big difference was the proper full radiator shroud. It doesn't care what kind of fan moves the air.
Miker
Where did you get the shroud? Who makes it?
Jim
Jim,
I'm running a BeCool aluminum radiator, with a custom built shroud. They offer a shroud, but I had some clearance problems, but theirs would have probably worked. With any radiator, the shroud needs to cover the whole area, and the fan should be 1/2 to 2/3rd's in side. Opinions vary. Seal the shroud to the radiator, you need to move air through all of it. The A/C coil is putting hotter air into the radiator, so any cooling problems get worse. Especially in higher ambient temps, when you use the A/C.
By Lou - 9 Years Ago
The splash pans acted as a fan shroud on the 54/56 Ford cars, most people take them off thinking they are only to stop water from splashing up on to the engine. The cars hood acted as the other haft of the shroud this set up not only worked to direct more air thru the radiator but caused the clean air to flow over the exhaust manifolds keeping the engine compartment somewhat cooler.
Thanks Mike
They are made in Texas and are plastic and split horizonal. I purchased one when I was having over heat problems. A smaller water pump pulley from a 302 eliminated my problems (thanks greenbird56). Like I usually do (over engineer) I spent some time sanding/fill priming to make it look like steel before test fitting. Well my power steering pulley was not the flat style, which these need or no PS, and the lower half of the shroud hit it, a good thing I didn't finish filling, priming, and sanding it. So I didn't use it. E-mail me at gmc6power and I'll send you photos if you want to see it and if you want will come up with a price and it be very fair I can guarantee that as I keep way too much.
56 Roger. Do you know where the rubber slash guards for the A-arm can be purchased? Mine are missing but attaching holes in the fender wells are there. If not maybe a photo of what they look like with demensions if possible.Thanks
By pegleg - 9 Years Ago
Concours had them for my '57
By junkyardjeff - 9 Years Ago
I put the splash pans back on my 37 scruby p/u and noticed less heat coming into the cab so I put them back on my 55,they do keep tools and bolts from going to the center of the car when dropped. I would like to put the deflector on top of the core support but would have to cut it up since I I moved the radiator in front of the core support like for a six to get more room for the 351-W so I will keep that part until the 292 goes in which will not be as soon as I would like it to be.
By carl - 9 Years Ago
DryLakesRacer (7/24/2016)
The holes are there on a 56 Ford for the a arm splash shields but they weren't used on the 56 like the 55.I think Ford left them off to get more air flow through the engine compartment plus cost cutting Ford also had a service bulletin to remove the splash guard above the radiator also to get more air flow through the engine compartment  Carl
By oldcarmark - 9 Years Ago
You can buy repro Rubbers and there is also a Metal reinforcement Piece that the mounting Bolts go through and then screw into the existing Holes in the inner Fenders. Tee-Bird.com sells them as well as most of the other Companies that sell Parts for these Cars. I have never heard of these not being used on the 56 Models although I don't doubt Carl's knowledge. The upper seal on the Rad Support was installed to keep hot Air under the Hood for winter driving according to another Member. I removed mine. Also was not aware the Shields under the Engine were there for any other reason than keeping Water from splashing into the Generator.I have a Pair I cleaned up and painted but never installed. I may try installing them and see if that helps with Coolant Temp. Always learning something new on this Site.
